Old 11-10-2008, 12:02 PM   #1
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
Changing Springs?
As some of you might Know I currently have Tanabe DF210's which is a 1.6" drop. I'm currently thinking about switching to NF210's which is a 1.1" drop. My wheels are 15". With the DF's I bottom out at 40+ speeds and have scraping on the front when going in and out of driveways and making high speed turns. My question is will switching to the NF's solve my problems, I mean how much is .5" when it comes to springs? I thank you in advance for your reply's.
bdc87 is offline   Reply With Quote
Old 11-10-2008, 12:05 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
did you cut the bump stops..
Old 11-10-2008, 05:15 PM   #3
bdc87
bdc87's Avatar
Yes.
Old 11-10-2008, 05:42 PM   #4
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Do you have the stock alloys?
If not what wheels do you have Size and offset and what tires are you running?
Old 11-10-2008, 06:07 PM   #5
bdc87
bdc87's Avatar
I have 15" Konig Heliums with Falken ZE912 205/50/15
I'm also wondering if changing to Tokico Blue Shocks would stop my problems. But my real question is if .5" is going to make a difference?
Old 11-10-2008, 06:27 PM   #6
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Your tires are just rubbing the fenderliner, it is not hurting anything. You coudl cut a small piece out of the fender liner and it will never rub.
The Blues will help keep from rubbing in the turns. They wont really help going in and out of driveways, unless you are taking those fast and that is why you are rubbing.
Old 11-10-2008, 07:17 PM   #7
bdc87
bdc87's Avatar
will the .5" stop the bottoming out?
Old 11-10-2008, 09:11 PM   #8
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Hell yes it will! I just put the nf's on along with tokico blues, and I no longer have to creep up or down a driveway in fear of scraping or screwing the car up. I had tein springs, but it did no good having 16'' wheels with a +40 offset and 195/50 tires.Just getting the Nf's alone will solve your problem of scraping and bottoming out.
marlondog is offline   Reply With Quote
Old 11-11-2008, 01:12 AM   #9
bdc87
bdc87's Avatar
Thank you marlondog for your words of experience. I shall do both then the NF's and Blues.
Old 11-11-2008, 03:55 AM   #10
dallas
Drives: Yaris Hatch /Landrover D2
Strange, some people have no problems with DF's and others do.
Did it bottom from the start or did the springs settle. I have DF'S but have not installed them yet.
dallas is offline   Reply With Quote
Old 11-11-2008, 03:24 PM   #11
bdc87
bdc87's Avatar
Springs settle and switch from stock 14" to 15" and roads here are worse then before because of new construction.
Old 11-11-2008, 06:52 PM   #12
marlondog
marlondog's Avatar
Another idea would be to get some 195/55 tires as well as some adjustable camber bolts in the front. The tires will lift you up a little as well as be a little narrower then the 205's. The camber bolts will also allow you to have your front tires angle in a little, so their more of a 42 offset then say a 38 or 40 offset. Good Luck!
Old 11-11-2008, 06:56 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
keep in mind, automatic trans cars are heavier and thus will cause more "scraping" issues
Old 11-12-2008, 01:15 AM   #14
bdc87
bdc87's Avatar
Or all my audio stuff like componet speakers, 2 amps, 12 sub, and custom trunk sub box.
Anyway contacted WSCP and plan to put my order in this weekend. This shall solve the problem and if I need a little bit more then I'll order the new camber bolts Garm just got in.
OK time to log off and watch some starsky and hutch.
Old 11-12-2008, 03:52 AM   #15
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
Blues and an Under panel will solve it. That plastic crap is whats scraping. Hangs down more than a half inch too.
ztrack157 is offline   Reply With Quote
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
