Old 11-12-2008, 12:49 PM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
3 more questions from a noob
I was looking at the engine bay this past weekend and some things puzzled me. I've never owned a "new" Toyota until now and it seems like some things have changed. Could someone help me out? They're probably easy to answer for you Yaris gurus. Thanks in advance :)
1) I could see the brake reservoir in case I need to fill brake fluid, but where is the reservoir for the clutch?
2) Did Toyota actually put the ECU in the engine bay, on the firewall? I've only seen ECUs in the cabin, usually under that dashboard. Is that just weird or what?
3) Am I correct that these 1NZ engines have an external water pump? So if it ever fails, I don't have to remove the timing belt (timing chain, in this case) to get to it?
Old 11-12-2008, 01:58 PM   #2
1stToyota
1stToyota's Avatar
1) M/Cyl must supply fluid to the S/Cyl
2) Common practice to put ECUs in the engine bay. Looks like ours get pretty good airflow around it
3) External pump
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Going to Dealer, questions on options. ejaf New YARIS Purchase Forum 24 11-19-2008 02:05 PM
Yaris Questions Tokiko New YARIS Purchase Forum 21 07-31-2007 07:36 PM
Noob questions. redduck Performance Modifications 14 06-18-2007 07:37 AM
Performance Noob Questions fatjerkgary Performance Modifications 20 05-11-2007 10:20 AM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 01:42 PM
