Old 11-13-2008, 09:07 AM   #1
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
after market sedan wiper & sizes
driver side: 26"
passenger: 14"
i used the anco contour blade for the driver side and just the refill for the passenger since there were no blades with the passenger size in stock or they just don't make it. not sure.
check the attachment, if you want to purchase it from your local auto store. this was recommended from some post here and suppose to be cheaper than oem.
just make sure you install the blade at the right position as shown in the guide otherwise the bottom of the blade wobbles during in use.
manborn is offline   Reply With Quote
Old 11-13-2008, 03:30 PM   #2
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
You got it right, 26/14!
Other manufacturers don't have "14" for the passenger side so their catalogs would recommend "13".
If you still want to stick with the OEM frame and blade, just replace rubber blade inserts. That may be "cheaper".
aca72 is offline   Reply With Quote
Old 11-13-2008, 04:34 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
You can't find refills here anymore. I've had to use el cheapo store brand for my 14" wiper.
Old 11-13-2008, 06:08 PM   #4
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
I got refills at the dealership for $4.00 a piece.
Old 11-13-2008, 08:09 PM   #5
I'm going to check out the dealership for refill blades when I get a break from nursing.
Old 11-13-2008, 08:39 PM   #6
PaidTimeOff
OMGWTFKITTYKATMEWMEWMEW
Drives: 2008 Yaris S
These sizes the same on the LB?
PaidTimeOff is offline   Reply With Quote
Old 11-14-2008, 01:30 AM   #7
YarisSedan
Drives: 08 Yaris Sedan
https://secure.eventurestudio.com/ww...etail.cfm?ID=2
Time for me to install some flexblades
Old 11-14-2008, 11:37 AM   #8
apparently, the LB uses different sizes. 24 and 15? but i found it odd they do that. i say best is ask the dealer or take your ruler out and mesure that up.
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 10:28 PM
Wiper Blade Sizes - 2007 Sedan? donairs Canada 14 12-14-2006 07:18 PM
