Old 11-13-2008, 06:23 PM   #1
at3GG
at3GG's Avatar
Drives: 07 metmet LB
TWM=??
I searched but couldnt find an exact answer. The TWM is just a shorter stick...correct? If so, then cutting the stock "stick" would achieve the same result?
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 11-13-2008, 08:01 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
TWM has some interesting articles on this very topic:
http://www.twmperformance.com/column...to-apples.html
Old 11-13-2008, 09:14 PM   #3
at3GG
at3GG's Avatar
Thats kind of more about competitors products and the quality of them. I would still probably buy the TWM before shortening my stock piece i was just wondering.
Tanabe Df210's
Old 11-13-2008, 09:23 PM   #4
I believe the short end of the stick is also lengthened a little bit compared to stock, and the shaft angled a tiny bit more. Not a huge difference but if you ever need to go back to your stock shifter...
Old 11-13-2008, 09:28 PM   #5
Jerkratt
Jerkratt's Avatar
Features:
- 2.4" height reduction
- 35% throw reduction
Fits:
- 2006 and up Toyota Yaris - North American Spec.
Included in kit:
- 2006+ Toyota Yaris Short Shifter
- All mounting hardware
- Special tool
- Installation manual (Download)
http://www.twmperformance.com/shorts...rtshifters.htm
i have this and the NST short shift kit
"It hurts more when its wet"
Old 11-13-2008, 11:08 PM   #6
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Originally Posted by Jerkratt View Post
Features:
Fits:
Included in kit:
- Special tool
+1 IT"S a Perfect Combo! hey Jerkratt did you get the bushings they are great also made it crisp and solid.
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 11-14-2008, 11:33 AM   #7
TWM Performance
Drives: 84 GTI, 90 GTR, 97 Si
Our TWM short shifters are not only chopped off versions of the stock shifter, they are real short shifters with relocated pivot points to change the angle the shifter travels between gears.
Here is a picture to show the difference between a stock shifter and a TWM short shifter bottom section, this is a Corolla shifter but the Yaris shifter is enginereed the same way:
It's the relocated pivot point that will achieve a great part of the throw reduction. Chopping off a part of the top section of your stock shifter will not achieve the same result as a real short shifter such as ours.
Thanks,
Frank
TWM Performance
TWM Performance is offline   Reply With Quote
Old 11-14-2008, 06:12 PM   #8
at3GG
at3GG's Avatar
Thank you thats all I was trying to figure out lol. I figured it had to be something more than a "chopped", or just shorter stick. I was just curious.
Tanabe Df210's
Old 11-14-2008, 09:42 PM   #9
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
TWM Short shifter are good shifters too....buddy has it in his Corrolla and it smoothed it out to drive a lot.
Old 11-15-2008, 11:52 AM   #10
Jerkratt
Jerkratt's Avatar
yes i got the shift bushing for the cage aswell with the TWM stick.. im still saving for the NST trans side bushing... atm i love the set up cant wait to see what the trans bushing do
Old 11-15-2008, 01:37 PM   #11
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Those bushings ROCK! you won't be disapointed
Hey since you got more buddies around see if someone can lend you a Stage 2 NST SSK to see if it works on the TMW it might work, It could be extreme but who knows?
R-CaT
Project Yar 2ZR
