Old 11-19-2008, 06:13 AM   #1
dorian
Drives: punto mk1 1100cc
hi
Hi there..do someone knows if the brake calipers..discs and caliper brackets fit my yaris1999 1000cc from a yaris 1300cc or a funcargo?
dorian is offline   Reply With Quote
Old 11-19-2008, 09:16 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
if they're from the same year (chassis) they should fit.. toyota gave up "upgraded brakes" on heavier cars in their cheap fleet.
Old 11-23-2008, 03:06 PM   #3
dorian
Thumbs up re
thanks man..i had measured the centres between the 2 bolds of the brake caliper carier..(the one which bolds to the stub axle) of my yaris and a funcargo..and they are the same..and even ta disc inside diamater are the same...but the outer diameter of the disc is bigger..so tha twill improve the braking! and even tha piston diameter are the same..so it wil no be affected the brake pedal travel...am I right?...
thanks.Dorian
