#1 |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
Anyone installed shocks?
Hi y'all. I've got a set of TRD shocks and springs but the included instructions don't really explain a whole lot for the shocks. Anyone done an installation of any brand of shocks and have pictures? Would help out a lot!
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
#3 | |
But cm07yaris, I just might take you up on that! I'm going to be going up in wisconsin to look at Northland College when I have some available time. Where in Wisconsin are you? |
#4 |
![]() ![]() ![]() ![]() Drives: 2007 Toyota Yaris Blazing Blue Join Date: May 2007
Drive up to Wisco, I'll do it for you!
#5 |
the rears are really easy, the top bolt is under the plastic cover in your trunk, and the
bottom is easy to see once you jack up the car and remove the wheel. If you have instructions for the springs, you're all set.
#6 |
HISTORY REPEATED 11/04/08
Rears are easy theres two nuts on each post under the plastic caps, I needed an impact wrench for these. And one bolt on each strut underneath connecting it to the frame.
Fronts are the hardest part and something I'm having a little trouble with but I have one on and working and the other tomorrow. If the sway bar end doesn't reach the top to install then you'll need to jack up the arm. Also a word of advice is use blocks and as many jack stands as you have. |
#7 |
Yikes, well, good thing I still have a bit of time to research!
#8 |
get over it. moderator's pet.
#9 |
![]() ![]() ![]() Drives: 2008 Yaris hatch Join Date: Oct 2008
I wrote the story for Siphon magazine on the install of the TRD components on the yaris with photos if that will help.
#10 | |
#11 |
If you visit NC bring em......I'll do it for nothing also. Well steak dinner would be nice.
#12 |
Magazine was cancled, Got the other side done today, yeah all 4 sides are done. Just wnet for a drive and it's totally different now, much more sure footed and stable, no more dips and the backroads are fun again. Will test highway soon.
| Installed the Tanabe Strut bar but had to remove my ground wire kit.. | vacantj | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-01-2007 01:56 PM |
| Which options are dealer installed? | grampi | New YARIS Purchase Forum | 4 | 07-30-2007 01:23 AM |
| Questions on Shocks | whooppee777 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 06-29-2007 06:19 PM |
| Tanabe NF210's installed...got a question though | Terrorize | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 09-29-2006 07:45 AM |
