Old 11-26-2008, 02:29 PM   #1
EstherK
Drives: Toyota Yaris 2007 Sedan
Faint smoky smell in car?
Over the last two days, I've been noticing a faint smoky smell in my car. I'm speculating that it came from the air conditioner/heater. I know that when I first used the heater, there was a burning smell. Then that went away. Am I just imagining things? What does this mean, if anything? I'm also wondering if it's from outside rather than originating in the car. Any help would be much appreciated.
EstherK is offline   Reply With Quote
Old 11-26-2008, 03:36 PM   #2
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
it's really hard to tell when were not there to smell it ourselfs...
Suggestions --> air freshener ?
id3379 is offline   Reply With Quote
Old 11-26-2008, 04:02 PM   #3
nsmitchell
nsmitchell's Avatar
Look for a small stoned elf in your back seat.
Get YarAss in gear!
RIP - Casey Tatum
Old 11-26-2008, 04:51 PM   #4
BailOut
Steals terrorist's lunch
BailOut's Avatar
Have you not had the heater on for a while? If not, it could have been dust settled in the system that cooked off.
- Brian
Share the Road
Old 11-26-2008, 05:39 PM   #5
TheSilkySmooth
TheSilkySmooth's Avatar
This happens more oft than naugt:
Person tosses cigarette butt out of moving car in front of you, butt finds way into ventilation system, car smells like stinky butt. If you are in disbelief there is TSB for Nissan (altima?)which are prone to sucking in discarded cigarettes into the engine intake and starting underhood fire
Open you glovebox and remove all parcels and deritis; push inwards sidewalls of box and jerk downward allowing box to override hinge stops. Now you can view the heater box area, there is gray-white rectangular shape cover with push tabs, you revove this cover and you can see into fan area (centrifugal-styled cage blower) and looking for Mouse and Squirrel nesting or other flotsam and jetsom.
Sonja's Papa
Old 11-26-2008, 06:30 PM   #6
Sonja's Papa
I don't think anything bigger than an uncooked RICE can find way inside the ventilation system. Not from outside anyways. Bugs and such can get in easy though, because they can crawl through other holes and such.. but if you look carefully. The only place of entry of fresh air is through the holes (with a grill under) right above the top of the hood. From the passenger side to be precise. So no.. a cig butt cannot blow through those holes and get into the system..
it's not like back in the days.. where you can actually get a wood stick through the vents :lol:
Car doors are not self-locking when left unlocked fainty_girl General Yaris / Vitz Discussion 27 03-14-2011 10:12 AM
big older car vs little newer car xed General Yaris / Vitz Discussion 9 09-16-2007 05:35 AM
NEVER LEAVE A TRIDENT WILD BLUEBERRY TWIST IN UR CAR Blenjar Off-topic / Other Cars / Everything else Discussions 7 09-16-2007 02:05 AM
Get your Yaris without waiting! costaricandreams New YARIS Purchase Forum 52 07-22-2006 11:42 AM
Buying a first car..lol Blenjar Off-topic / Other Cars / Everything else Discussions 11 06-14-2006 12:58 AM
