Old 11-26-2008, 07:36 PM   #1
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Computer Expert Help
after i restore my dell desktop, my cdrom can read only, when i'm try to burn the cd or dvd it's will stop at 11% and eject the disc and said burn failed.
I tried couple different programs, cd brands...all the same. Try to update and still not working
Any idea what's wrong with it?
Thanks
Old 11-26-2008, 07:48 PM   #2
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
More than likely you are running out of resources. How many items are loaded in your start up? I used to have that problem years ago with an older computer. I used to open the system tray and close anything I was not using.
Old 11-26-2008, 07:51 PM   #3
bnther36
Drives: 07 Yaris Sedan
Have you looked to see if the Device Manager shows a loaded driver? If not, go to the Dell website, they'll have everything you need to ensure that all drivers are loaded.
bnther36 is offline   Reply With Quote
Old 11-26-2008, 07:55 PM   #4
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
Mabie your Rom is crappin out,
id3379 is offline   Reply With Quote
Old 11-26-2008, 08:20 PM   #5
jamal1984
thanks yup check that, i'm fine got plenty of performance left
What's Loaded Driver? When i'm check my device manager i see CD/DVD Drive - Right Click - Update Driver-Disable-Uninstall-Scan for Hardware change-Properties, tried uninstall reinstall, and still not working.
Hope not man, this is like laptop cdrom it's really not easy to replace it. wouldn't buy another dell computer, i support to have another 6 months warranty, and they are trying to bs with my warranty now. They said there is something wrong with my warranty, and i need to call back on business hour 8-5 to verifi.
Old 11-26-2008, 10:16 PM   #6
Thanks
If the drive is IDE, make sure Ultra DMA is enabled.
Go to control panel, system, device manager.
Locate the IDE ATA/ATAPI controllers and expand.
On each channel, double click, then on the advanced settings tab set transfer mode to "DMA if available" for each device under the channel.
If that doesn't help, it is probably a bad burner. I wear them out in less than a year on my desktop...
Old 11-26-2008, 10:33 PM   #7
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
loaded driver. i think he's referring to the correct driver of your dvd/cd-rom! if you right click onto the properties, you should be able to see a tab named "driver", click that and then click the "driver details" button.
i think, you have to make sure that you are using the right driver for that specific drive(cd-rom/dvd)...sometimes microsoft will just put a generic driver and the hardware will not function properly!
I Have Become A Geek, My New Computer Set-Up.... The Architect Off-topic / Other Cars / Everything else Discussions 43 11-22-2008 03:50 PM
Computer webmaster In Car Entertainment + Electronics (audio / video / alarm) 54 03-13-2007 06:19 PM
