Old 11-28-2008, 04:00 AM   #1
gwasabi
Drives: 07 Blazing Blue LB
Exhaust pipe size
Does anyone know the Stock exhaust pipe size? I was planning to do the secondary cat delete and wanted to know what size pipe i need to weld on.
gwasabi is offline   Reply With Quote
Old 11-28-2008, 05:48 AM   #2
1.75"
pretty sure we only have one cat and the resonator after it....
and from what magnaflow was saying, the cat and res are 2" straight thru
so if youre staying n/a id just do a res-back exhaust at 2" diameter...
Old 11-28-2008, 12:52 PM   #3
We have two cats (USDM). The O2 sensor is right between them, then after the 2nd cat comes the resonator.
Old 11-28-2008, 12:59 PM   #4
josevenezolano
Drives: Toyota Yaris HB 2008
Yes, My Yaris is made in Japan and it has two cats.
josevenezolano is offline   Reply With Quote
Old 11-28-2008, 01:57 PM   #5
oh, didnt know that...i guess i havent really looked under the car too thuroughly....
Old 11-28-2008, 02:21 PM   #6
gwasabi
Hmmm.....REally our pipes are that small? I plan on going turbo eventually so maybe I'll just keep the cat.....plus I only have 3" extra pipe anyway. I don't think I have a resonator. I have a greddy tic so just a muffler. Maybe when I end up turboing my car I'll just delete everything and weld the muffle back on to a 3" pipe. What do you guys think?
Old 11-28-2008, 02:55 PM   #7
Split
Drives: 2008 Yaris Sedan
i can't imagine piping being expensive. its really easy to delete that second cat, and if you're really ambitious you can remove the resonator right next to it as well, you just need to weld a new hanger on the pipe after.
Split is offline   Reply With Quote
Old 11-28-2008, 03:32 PM   #8
gwasabi
I don't think we have a resonator.... I thought the resonator is the part in the back right before the outlet. As far as I know it goes cat, 02 sensor, cat, resognator, then tip
right now I think mine is cat, 02 sensor, cat, muffler.
From what I know the axle back exhausts gets rid of the resonator. I dunno maybe I'll just work on a straight pipe for once i get a turbo
Old 11-28-2008, 04:46 PM   #9
Axle backs just replace the portion of the exhaust system at the rear axle. Magnaflows' "cat-back" is like my custom set up, it actually starts from the end of the resonator (resonator back).
Old 11-28-2008, 04:47 PM   #10
Piping prices depend on the material used; i.e. steel, titanium, etc, and also the method used to bend them; i.e. crush bends or mandrel bends (more expensive).
Old 11-28-2008, 04:49 PM   #11
Honestly, if you are going to delete the second cat, might as well do away with both. I was going to do that, and the shop gave me a warning that if a highway patrol pulls me over and see's that there's only one cat, then they can impound my car. But then again, how do they know that our car comes with a primary and secondary cat?
Old 11-28-2008, 05:39 PM   #12
The resonator is the long tube right under the middle of the car, after the 2nd cat. The part in back before the tip is the muffler.
header - cat - O2 sensor - cat - resonator - piping - muffler - tip
Take a look at the Nitto midpipe, it simulates your stock set up:
Old 11-28-2008, 06:13 PM   #13
TheSilkySmooth
TheSilkySmooth's Avatar
I thought all lambda control cars are header-02-cat-02-cat-resonator-muff. Some people call the first 02 a mixture sensor, since ours is the megadollar 0-5volt wideband not the 0-1 v wave/pulse. You gotta measure the mixture b4 its in a cat so the ECU knows the mixture. Remember, this is a 1.5L LOW rEVVING motor not a honda vtec that spins to 7500+ A 2" DIA system is plenty too big enough to kill most power under 3500 rpm.
Sonja's Bro
Old 11-28-2008, 06:18 PM   #14
WolfWings
WolfWings's Avatar
The long-tube exhaust header Richard's been testing shows our engine benefits up to around 2.25" exhaust actually, for NA at least. No gains (no mention of losses either) going up to 2.5", but yeah, unless you're going turbo no reason to go over 2.25" it looks like.
Old 04-17-2013, 01:39 PM   #15
djhuddy2442
djhuddy2442's Avatar
Drives: 2008 toyota yaris hatchback
1.75"
is the 1.75 the inside or outside diameter???
djhuddy2442 is offline   Reply With Quote
Old 04-19-2013, 02:03 PM   #16
I.D.
Old 04-19-2013, 02:26 PM   #17
Jason@SportsCar
A better image to go with your description.
#1 header
#5 resonator
#10 muffler
The two cats are just ahead of the resonator in this illustration.
Old 04-20-2013, 10:04 AM   #18
djhuddy2442
so what would be the O.D. of the pipe??
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
Exhaust pipe gasket umm_bacon DIY / Maintenance / Service 1 09-23-2007 07:30 PM
white residue in exhaust pipe yuiedie DIY / Maintenance / Service 7 09-21-2007 07:17 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
