Old 11-29-2008, 01:46 PM   #1
bms1990M3
bms1990M3's Avatar
Drives: '08 3 sedan
adjusting headlights
i put some HIDs in my girls sedan. i can not, for the life of me, figure out how to adjust the height of the light output. any help would be rellllly appreciated. there has to be a screw somewhere......
bms1990M3 is offline   Reply With Quote
Old 11-29-2008, 08:51 PM   #2
bms1990M3
bms1990M3's Avatar
Drives: '08 3 sedan
no replies???
My pic thread: http://www.mazda3forums.com/index.ph...705#msg2587705
Old 11-29-2008, 09:00 PM   #3
Revsson
I haven't tried it, but check out the service manual for lighting:
http://www.etimago.com/yaris/repairmanual/Lighting.pdf
Look at page 89 of the pdf file. It shows some info on aiming the
headlights for the sedan.
HTH
Old 11-29-2008, 09:24 PM   #4
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
On the HB theres are phillips slot on the back of the headlights you turn them left or right to lower or raise
bdc87 is offline   Reply With Quote
Old 11-29-2008, 09:31 PM   #5
bms1990M3
bms1990M3's Avatar
Drives: '08 3 sedan
i wonder if it is the same for the sedan?????? i have not seen her for a while so i can not like go right outside to look. :(
Old 04-08-2010, 11:39 AM   #6
djct_watt
Drives: 2010 NCP91 5spd
bump. . . the headlight design has changed for the 2009/10, and there are now two adjusters, one readily accessible and exposed towards, very close to the grill, and another buried behind everything underneath the headlight, on the the side opposite of the grill. It's would be impossible to reach the other adjustment screw, requiring removal of the headlight, which would make aiming all but impossible.
Hopefully someone else has done this and give pointers. I'm really hoping it's not the buried adjuster!!!
djct_watt is offline   Reply With Quote
Old 04-08-2010, 08:26 PM   #7
djct_watt
Awesome! I'm hoping it's the same on the (newer) hatch. Gonna just have to experiment. Thanks!
And yes I have full glare shields. But out here "legal" and "glare" are a small concern.
Old 04-08-2010, 09:40 PM   #8
LA Yaris
Yaris323
LA Yaris's Avatar
This part adjust the height turn it to the left or right to adjust Up and Down.
That's how I did it with my Sedan with HID'S.
Old 04-08-2010, 11:02 PM   #9
yarrr
Drives: 07 sedan
Originally Posted by camelll View Post
Was my post not clear enough???
it definitely needed more red arrows
Old 04-09-2010, 01:38 AM   #10
LA Yaris
Yaris323
LA Yaris's Avatar
Not so good of telling time
Old 04-09-2010, 01:47 AM   #11
djct_watt
I will try this tonight on my 2010 Yaris (hatch) and will report back, so we'll have a record for the future.
Old 04-09-2010, 04:44 PM   #12
djct_watt
Yes, it is different on the hatch, which is why I have to test it out. What's worse is that the 09/10 headlights have a newer design which is also different from the rest of the hatches. Didn't get a chance to adjust them yet. . . will hopefully get a chance tomorrow.
Old 04-15-2010, 11:09 AM   #13
djct_watt
Yup, it's the right one for the 2010.
Old 04-15-2010, 11:46 AM   #14
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
I notice from camell's pics that...the 2008 Corolla models have the same nut of adjusting the height of the lights.
Yes, the liftback is different in adjusting.
djct Watt - the screws can be see when having the hood open. White plastic screw on each side near the top corner, nearest to the front bumper~
What temp to bake headlights? PETERPOOP DIY / Maintenance / Service 23 04-27-2009 01:39 PM
WTB headlights Turbo&Auto Items for Sale by private party 0 06-08-2007 07:31 AM
JDM headlights yrsdrgn Cosmetic Modifications (Exterior/Interior) 6 02-13-2007 10:52 AM
WTB: Yaris Liftback Taillights and Headlights TRD_Yaris Items for Sale by private party 9 07-24-2006 03:44 AM
Clear Corner Headlights Ran Kizama Cosmetic Modifications (Exterior/Interior) 6 07-06-2006 02:43 PM
