Old 11-30-2008, 08:48 AM   #1
Prohibit
Verbieten Sie
Prohibit's Avatar
Drives: 2007 Liftback
Send a message via AIM to Prohibit Send a message via MSN to Prohibit Send a message via Yahoo to Prohibit
Another "HELP!!" Thread
So, I am not the brightest crayon in the box when it comes to wheel/tire fitment. I look at the sizes guide and I just get a blank look on my face.
The Wheels: Konig Helium 15x6.5 4x100 40mm offset 73.1mm hub bore
The Tires: 185/60/15
Thank you for your time.
Hatchback Purist? Be sure to drop in and register. New forum with a great clean design and potential.
Prohibit is offline   Reply With Quote
Old 11-30-2008, 09:26 AM   #2
Those specs are all good. Hub bore is larger than our hubs but distributer should take care of that by providing properly sized hub centering rings. The +40 offset might tuck the wheels in a little too much on a 15X6.5, but there are others who are far more knowledgeable than me when it comes to dealing with offset. My feeling would be +35 on this wheel.
Your car, the way it is transforming, would be screaming out for a wheel larger than 15". Bump her up to 16s at least to maintain ride quality and deal safely with crappy roads.
Old 11-30-2008, 09:38 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Excellent fitment. Go for it. No worries.
Old 11-30-2008, 11:21 AM   #4
Prohibit
Verbieten Sie
Prohibit's Avatar
Thank you, i'll probably email the company and see what kind of deal I can get on 16's. The problem I am faced with is I have to take a 12 hour trip from home back to here on January 2nd - and I have 2 bent rims on the car right now. So my options are to either buy a full set of 15's with new rubber, or two new steelies and save up for 16's.
UPDATE
Okay, so, my mom just sent me $300 for a plane ticket home and the ticket ended up being only $150. She told me to keep the change, so I have an extra $150 to throw down on bigger rims. Guess 16's it is. Just gotta look for tires now. I'm going to post up some sizes again in a few and I'd appreciate your responses. Thanks!
Okay so how about this.
WHEELS: 16x7 4x100 40mm offset 73.1 mm hub bore
TIRES: Sumitomo HTR Z II 205/45ZR16
Old 11-30-2008, 03:17 PM   #5
205/50/16 is preferred for OEM diameter, will give you a bit more rubber too.
is the car lowered?
Old 11-30-2008, 03:22 PM   #6
Prohibit
Verbieten Sie
Prohibit's Avatar
205/50/16 is preferred for OEM diameter, will give you a bit more rubber too. is the car lowered?
Planning on buying the $160.00 kit from you.
Old 11-30-2008, 04:44 PM   #7
kimona
kimona's Avatar
16x7, ET40, 195/50/16
16x7, ET42-45, 205/50/16
Shift lever thread size Chaad32 Cosmetic Modifications (Exterior/Interior) 16 01-30-2015 02:16 PM
Shift Knob Thread Patter? eight_heads General Yaris / Vitz Discussion 6 10-21-2009 10:25 AM
Latka's Yaris thread Latka Hawaii 9 11-12-2008 03:03 PM
Is there a thread about..... Letsrock Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-01-2008 12:25 PM
Post Whores-aka Yaris chat thread Black Yaris Off-topic / Other Cars / Everything else Discussions 21 07-12-2007 05:37 PM
