Old 12-06-2008, 02:01 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
How did you run the wideband A/F cable into the car?
I just got a wideband A/F gauge and the sensor unit needs about a 1 inch hole to feed through. The other end is a rectangular plug and needs a 1 1/4" square hole.
I figured the 1" hole would be easer. I'll be getting a bung welded to my midpipe right after the Megan header. The exterior cable with the two ends mentioned above is only about a foot long.
Is there a large enough feedthrough that exists or did you guys drill new holes into the car?
TIA
big older car vs little newer car xed General Yaris / Vitz Discussion 9 09-16-2007 04:35 AM
New Siphon Mag: Yaris vs. xA vs. Versa vs. Fit @ Streets of Willow Ran Kizama General Yaris / Vitz Discussion 9 06-18-2007 12:42 AM
where to run amp positive cable??? punch In Car Entertainment + Electronics (audio / video / alarm) 8 12-21-2006 07:50 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
Buying a first car..lol Blenjar Off-topic / Other Cars / Everything else Discussions 11 06-13-2006 11:58 PM
