Old 12-06-2008, 06:15 PM   #1
Chupacabra
Drives: 2009 Yaris liftback
2006 Scion Xa steel wheels...
Can anybody confirm that the '06 Scion Xa wheels are the same as the 15" Yaris steel wheels? Thanks guys!
Chupacabra is offline   Reply With Quote
Old 12-06-2008, 06:58 PM   #2
pixiedixie862
Drives: Scion xA
i believe they are.
pixiedixie862 is offline   Reply With Quote
Old 12-06-2008, 09:02 PM   #3
03Z33
03Z33's Avatar
Drives: TCR10
Yes, same tire size also.
03Z33 is offline   Reply With Quote
Old 12-06-2008, 09:04 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
xa and yaris are the same.... xb's are different
Old 12-06-2008, 11:11 PM   #5
hub bore may be a bit bigger, but theyll fit
Old 12-07-2008, 04:21 AM   #6
03Z33
03Z33's Avatar
Drives: TCR10
It's still 54.1mm hub bore. All smaller Toyota/Scion/Netz cars share this hub bore.
Old 12-07-2008, 06:56 AM   #7
oh....ok....i only say this as i bought some winter steelies/tire from a guy who had an echo hatchback. i put them on the yaris and the bore was too big (though they fit perfectly on the aveo which has a slightly larger bore). but i guess that means one of two things: either youre wrong, or buddy just had wheels on his car w/ too big of a center bore (im guessing the latter). however, did garm ever work out the rear disc brakes from an echo/vitz?
Old 12-07-2008, 07:04 AM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
Perfect fit.
Old 12-07-2008, 08:02 AM   #9
Chupacabra
Guys...thanks. So....what is the center bore on the wheels? We use a 67.1mm correct?
Old 12-07-2008, 08:34 AM   #10
kimona
kimona's Avatar
I believe it's 54.1.
Old 12-07-2008, 08:41 AM   #11
Chupacabra
I guess that I just want to make sure that they'll be a perfect/stock fit for the Yaris. This is the case, correct? Thanks Kimona!
Old 12-07-2008, 12:04 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
yes, all toyotas have the same hub bore
Old 12-07-2008, 12:23 PM   #13
Chupacabra
Thank you! I am new to the world of Toyota's so I apologize in advance for my naivity.
Old 12-07-2008, 06:52 PM   #14
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
WHAT, i guess thats out in your neck of the woods. over here its the same damm wheel.......
KYB shocks and Steel stock wheels White Yaris Items for Sale by private party 15 11-18-2008 09:26 PM
Scion xD Rudeshady Central and South America 1 06-25-2007 01:11 PM
Steel Wheels Sabretooth Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 04-04-2007 07:40 PM
15 inch steel wheels Bretsuaz Items for Sale by private party 6 03-24-2007 08:25 AM
15-in. Steel Wheels vs.14 in. Wheels hans_fh Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 10-16-2006 12:06 AM
