Old 12-09-2008, 09:58 PM   #1
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
TRD Lowering Springs
SOLD!!!!
For sale is a slightly-used set of TRD lowering springs. I bought them from another YW user who had them installed for 4 months, then sold them to me (he went lower), and I installed them for 2 days, but had to pull them since my wheels rub up front when i corner hard. I have 215-40-17's w/ a +40 offset, so its just a bit too wide for these. The drop was perfect, and felt very nice. NOT a rough ride, and it hardly felt different from stock springs, other than a little better in the corners. I'm quite picky about keeping my car comfy and a daily driver, and these were great. Very bummed that my wheels aren't a good match. I did run them with the stock wheels/tires just to confirm that it was my wheels, and I had no rubbing, even when taking a freeway cloverleaf at 50 mph.
$90 + shipping (should be under $20 in the lower 48.) Local pickup is free in DFW.
ozmdd is offline
Old 12-11-2008, 11:44 AM   #2
Tonavi
Tonavi's Avatar
Drives: 2007 Yaris HB
I'd be interested, but how much work are they to install? Can it be done with relatively basic tools?
Thanks
Tonavi is offline
Old 12-11-2008, 04:24 PM   #3
wow great price!
Thanks
can be swapped in a couple hours....a spring compressor is the only non-standard toolbox item
thebarber is offline
Old 12-16-2008, 10:55 AM   #4
ozmdd
ozmdd's Avatar
Yes, the tools you need are:
-Spring compressor ($20 @ Harbor Freight, $35 @ AutoZone, free to "loan" from most parts stores)
-19mm, 17mm and 14mm sockets
17mm wrench (offset box wrench makes the strut tower bolts MUCH easier)
6mm allen wrench
Jack and jack stands.
I'm pretty sure that's it. There is a great DIY on this site, and I was able to install them in just over 3 hours the first time, 2 1/4 hours when I switched back to originals (solo!)
I'm a pretty decent mechanic, but nothing beyond basic wrenching here. All the parts are easy to access and very easy to see. The only exception is that taking off the strut top bolts is a bit tedious, but actually very easy if you just take your time and use an offset box. I didn't remove the wipers and plastic shroud the second time, as the DIY suggests,and found it was no problem. Its the slowest part of the project with or without the shroud removed, but less than 10 minutes per side.
The rears are so easy that you'll think you forgot something. Less than 30 minutes, even with a smoke break! If you can change brakes, you can do this. BTW - price is now $90+shipping. I wanna get me a sway bar! :)
ozmdd is offline
Old 12-16-2008, 11:43 AM   #5
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
I uninstalled my springs without the compressor. Wish you would of had these for sale before I bough my NF's. Anyway free bumb for a great price.
bdc87 is offline
Old 12-16-2008, 12:12 PM   #6
tuckevalastin
tuckevalastin's Avatar
Drives: 2008 Yaris Sedan
if these are still around in a week or so I may be interested
tuckevalastin is offline
Old 12-21-2008, 09:42 PM   #7
ozmdd
ozmdd's Avatar
Bump... still got em. Shipping will be $20 or less anywhere in the lower 48. I'll eat the difference if it's more.
ozmdd is offline
Old 12-22-2008, 12:22 AM   #8
Why didn't you change the camber and get those to tuck better?
cali yaris is offline
Old 12-22-2008, 12:25 AM   #9
laszlo
laszlo's Avatar
Drives: 2007 black 3 dr
that sound like a good deal
laszlo is offline
Old 12-22-2008, 11:20 AM   #10
ozmdd
ozmdd's Avatar
Sold!!
ozmdd is offline
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 12:42 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
TRD Lowering Springs DJ_Trizzak Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 07-06-2006 11:20 AM
