Old 08-02-2006, 10:56 PM   #1
hhcchen
stop staring my star perv
hhcchen's Avatar
Drives: 97 tercel
under hood insulation
ok...
what's the deal with some yaris having a piece of black insulation under the hood while some others don't...
if someone can find a better picture with the hood insulation...
hhcchen is offline   Reply With Quote
Old 08-03-2006, 12:29 AM   #2
johnnyfive
johnnyfive's Avatar
may be neither here nore there, but my S sedan has one...dont know if it came with the sedan, or part of the S package, or cold weather pkg...just dont know ;)
Old 08-03-2006, 12:51 AM   #3
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
it helps keep the paint from fading and blistering from the heat of the engine
Found out the hard way after removing it from my Beretta.
Paint on the hood went bad in less then a year and the clear coat started to peel off.
Old 08-03-2006, 01:11 AM   #4
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
there might be different req't for different areas. It is also a fire-extinguishing blanket that covers the engine in the event of an under hood fire.
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 08-03-2006, 11:02 AM   #5
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Yea, its weird.. our BMWs have it, both Nissan's do, my Ford doesn't and now neither does the Yaris.
Old 08-03-2006, 11:05 AM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
My S doesn't have it however I will want to know if I need to look into that...let us know if someone finds out more.
Old 08-03-2006, 03:37 PM   #7
rstb88
rstb88's Avatar
Drives: Silver Hatchback
the Beretta did it cause its a chevy and chevies in my experience have paint problems. and the little I4 doesn't get that hot I'm sure your had the 3.1, am I correct. and I want one so that the hood won't be so hot.
"Automatic carwashes are like Hookers........are you sure you want to use it next???? (Jer)"
rstb88 is offline   Reply With Quote
Old 08-03-2006, 05:16 PM   #8
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
Chrysler was the one with bad paint probolems...... I would like to get one if I could. Sounds like a good idea to me.
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 08-03-2006, 05:17 PM   #9
Chaad32
Chaad32's Avatar
Notice the air intake in the top pictured car!!!!
2007 Liftback
Blazing Blue
Old 08-03-2006, 05:21 PM   #10
sroberts
sroberts's Avatar
Drives: 2007 Yaris Sedan
I'm pretty sure it part of the cold weather package. Helps the engine get up to temp sooner.
I am not allowed to put anything here because I do not have any ricey mods on my Yaris....
sroberts is offline   Reply With Quote
Old 08-03-2006, 06:13 PM   #11
Chris07LB
Chris07LB's Avatar
Thats the BLITZ setup, and I believe thats also HYDE's car... both of which I have asked several times for more pictures of.
Old 08-03-2006, 09:15 PM   #12
PerennialPursuit
Drives: 07 yaris sadan-auto-flint mica
i think you are right. i have a sedan with
the weather package and it has one also.
not sure about it warming up sooner though.
PerennialPursuit is offline   Reply With Quote
Old 08-04-2006, 12:39 AM   #13
johnnyfive
johnnyfive's Avatar
@ fnkngrv - you baught your yaris in Minnesota, right? so it has the cold weather package, but no hood mat? interesting...
Old 08-04-2006, 06:57 AM   #14
Boo
Boo's Avatar
Drives: PW Yaris LB AT
It is not necessary.. I found a strip down yaris with no package on the dealer lot here in Wisconsin.
Boo is offline   Reply With Quote
Old 08-04-2006, 07:27 AM   #15
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
My liftback has the cold weather package but no insulation.
Old 08-04-2006, 09:13 AM   #16
fnkngrv
fnkngrv's Avatar
I apologize....My S does have it...hadn't noticed before, but I popped the hood to show someone today and saw it there.
Old 08-04-2006, 09:31 AM   #17
sroberts
sroberts's Avatar
Well then, I cannot think of any other reason why it would be on some and not on others. Living in several different colder climate cities, I have always installed insulation to help warm up the engine in the winter. I can't imagine that these little engines get hot enough to blister the paint and would need insulation for that. Why is it on some and not others I wonder
Old 08-04-2006, 09:32 AM   #18
Chris07LB
Chris07LB's Avatar
Same here.
Canadian members. lappie General Yaris / Vitz Discussion 231 03-01-2007 05:23 PM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 02:43 PM
HELP! paint dings in the hood... oktaren Cosmetic Modifications (Exterior/Interior) 23 08-01-2006 09:20 AM
C-ONE CF HOOD C2AUTOSPL Cosmetic Modifications (Exterior/Interior) 20 07-20-2006 12:34 AM
lift the hood wushumasterku General Yaris / Vitz Discussion 9 06-02-2006 01:57 AM
