Old 12-12-2008, 02:57 AM   #1
GeneW
Drives: 2008 Yaris
Joy of Flying (hazardous conditions)
Around lunch time today the weather was a "wintry mix", a combination of freezing rain, sleet and snow. The temperatures fell close to freezing and it started to sleet, transitioning into snow.
By late evening the road crews had given up, leaving the roads to their fate, except for applications of salt. The slush was building up and made the roads kind of tricky.
I left work a bit after midnight, tired but looking forward to the challenge. I knew if I got scared the trip would be a horror show so I decided to have some fun instead. Slightly raised the risk in one sense, drastically lowered it in another. Being scared in bad weather is not a good idea.
Ambient was about 32 Fahrenheit, or 0 Celsius. Standard Yaris with AT and M&S tires, probably at seventy percent tread.
Prepared for the trip home by donning the helmet and then playing in the parking lot. The lot had a cover of heavy "wet" snow about three inches thick. Did some bootlegs, controlled skids and so on. Took the car across the street to another business and sailed up their drive, which is about a thirty degree slope. No problems were encountered going up or down, which on the downhill run included controlled skids. The car responded very well to usual countermeasures.
I cannot over emphasize how this preliminary "play" helped me understand the limits of the car in the current conditions. Practicing skids going downhill, normally the worst kind of experience one can obtain, gives one a sense of stopping distance, which gives you an idea of how fast you can go.
The roads were dicey, covered in about two to three inches of thick wet snow. The road crews surrendered and didn't bother to plow, they just applied salt. Might as well have screamed at the stuff for all the good that it did.
Shut off the music, got in tune with the process and paid strict attention to the road and intuition. Felt edge of "instability" and stayed under it. Maintained visual focus for the most part on where I wanted to go since under stress one will tend to steer where they look. Only took glances from side to side and in mirrors as habit and no more.
Butt and back sensations are critical to maintaining stability. Seat of the pants is not just an expression, it is critical to keep the car on the road.
Average speed on the way home was 36 miles an hour per Scangage. Peaked at about fifty miles an hour on the high speed limited access roads but never really dropped below 25 miles an hour except in town on flat roads.
It wasn't as dangerous as it sounded.... the Yaris needs to breathe and move in bad snow. It does not like to "grind" and does not really "Dig in" too well, but it will manage nicely in heavy snow if you respect its limits.
Passed the following....
Pickup doing 27 miles an hour. He pulled out on front of me and then proceeded to drive slowly.
Official Salt truck doing ten miles an hour. I waved to him in appreciation for his efforts though plowing the roads would have been a better bet.
Two pickups going along like baby elephants at about twenty miles an hour.
When I made it onto a Toll road the conditions were not much better but I did not need to account for people coming from the side. I picked it up to fifty miles an hour, the limit of perturbation.
Passed a RAV4 which was barely holding its own, including using "hazards". Since it was a fellow Toyota pilot I tooted the horn at them.
Passed a high performance Nissan which was driving in the shoulder, an Alero driving on the other side of the road on the shoulder and a pickup truck which I guess was shepherding them home. There was ample room between them so I passed down the middle. Total foolishness to take both shoulders when they could have gone in a row together.
Made it home in an hour. Normally the run takes me about forty minutes if I take it easy. I'm still a bit giddy about it, since I know that it is dangerous out there, but I handled surprises and hazards better making a game of it than if I had been afraid, tense and expected disaster around every corner.
Debrief
1. Car ground a bit going up hills at slower speeds. Did quite well when kept above about twenty miles an hour.
2. Rear end got flaky around fifty miles an hour in deep wet snow. This agrees with previous experience. I usually would cut it back if things grew bad but in time I'd pick it up again - sort of a pulse and glide in the other direction.
3. Focus is absolutely essential under these conditions. Especially when ruts in the road try to toss the car off of the road. I did not brake but let the drag of the snow slow me down. Worked like a charm.
4. Snow? Get Snow tires. I have Kelly Springfield M&S tires, thirty years of experience on the road and a lot of theory about Perturbation and Stability. Math isn't a waste of time and snow tires are not a waste of money.
The Yaris can tackle bad weather, if you put the right shoes on it, respect its limits and give it room to breathe and move.
gene
Old 12-12-2008, 03:47 AM   #2
1NZYaris1
1NZYaris1's Avatar
Sounds like you had a ball, you could almost start a new venture .
Snow rides in a yaris
Old 12-12-2008, 03:07 PM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
This is the ONLY thing I miss about winter. Driving in snow and ice (with no traffic) is a challenge. Try black-ice covered freeway with a heavy cross-wind in a Miata sometime. ;)
Old 12-12-2008, 03:09 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
best car i ever drove in snow was my MKI MR2.. 3 winters and not one time in the ditch!
Old 12-12-2008, 04:21 PM   #5
1NZYaris1
1NZYaris1's Avatar
UHHHHM thats got to because of the driver , not the car.
Old 12-12-2008, 04:52 PM   #6
My 1982 Cressida for me, freakin awesome with no problems no matter what the condition.
Old 12-12-2008, 06:30 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
lol it was my first car... ironically totaled it on a perfectly dry day... took a blind corner to find an SUV coming the other direction in MY LANE.. panicked and lifted off.. not a good idea in an MR car.. god i miss that car :(
but back on topic, driving in snow is an amazing feeling
Old 12-12-2008, 07:36 PM   #8
Rich k
Rich k's Avatar
Drives: 07 3dr white Yaris 5spd stock
Send a message via AIM to Rich k
Thanks for the description and the debrief. Very much what i noticed with the yaris last winter, its a surprisingly stable car in the snow. Good job on taking it for some test slides and getting it unsettled and seeing how it reacted when you tried to get it back in line. Not enough people do this and end up having to learn the cars snow handling charecteristics in an emergency situation, which is just a bad idea. Happy you got home safe.
Rich k is offline   Reply With Quote
Old 12-12-2008, 07:43 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by Rich k View Post
Not enough people do this and end up having to learn the cars snow handling charecteristics in an emergency situation.
and this is why i believe that drivers should be forced to take an aptitude test before receiving their license.. you have to be able to recover from an emergency situation without causing harm to others or your self..
but this isn't germany,, this is ObamaLand!
Old 12-12-2008, 07:49 PM   #10
Rich k
Rich k's Avatar
Ohhh that test would be a great idea. I like it. Driving test is sooooo dopey. Drive, turn, broken k, parallell park all in broad daylight in non rush hour situations ususally in pretty great weather and not even any highway component. Ok here ya go, drive safe. Common sence would dictate that it should be more comprehensive.
Old 12-12-2008, 07:52 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
i also think that reaction time tests should be implemented and would decide what YOUR speed limit is..
if you can't pass an RT test you have to drive posted speed limit.. if you ace the RT test you can travel up to 20mph over the speed limit.. with zero tolerance for failure of course..
but again, never gonna happen in the US
Old 12-13-2008, 08:26 PM   #12
GeneW
Drives: 2008 Yaris
We do have such a test. If you fail the test you get hurt or die. If you pass you get to continue on. It's more Darwinian except that most of us prepare first.
Earlier that day I passed an accident, during the wet rainy period. Anyone care to take a guess what they were driving?
An SUV, I think an Escalade. The damn thing ended half up on the Jersey Barrier. Don't know about the other car. I shrugged, figured it was some dumbass on their cell who wasn't "there" and got nicked. Hope that they weren't messed up.
The real challenge for most drivers, I think, is being there while operating the car. I rarely meet bikers who get into such jams, driving aware is second nature to them.
Rich, you're welcome.
Gene
Old 12-13-2008, 08:41 PM   #13
GeneW
Drives: 2008 Yaris
How would you tell one driver apart from the other? Would we be assigned colored coded cars? Would Big Brother live inside of our cars, checking up on us?
What if the person who tested high on reaction time was under-rested or worked a ten or twelve hour long day at work? What of zero-tolerance then? Would the car give you a little test to see if you could hack it?
What if people could take drugs that speed up reaction time? What if the drugs failed to work?
Is someone who tests well fast enough that they can carry on a conversation, dial the radio or select a CD track and still drive? How would you prove under zero-tolerance that they were in error?
Incidentally, I have a phrase for "zero-tolerance", I call it "Zero-Intelligence". I'm not hammering on you, just pointing out how often this phrase is abused for various reasons. Kids holding chicken fingers like a gun and saying "bang" get suspension while kids holding pencils and having fits are ignored because they're "under care".
Lot easier to just keep the speed limits, sort of enforce them and let things settle themselves out.
Gene
Flying toast and jelly cadence220 Photo-Video-Media Gallery 11 07-24-2006 06:39 PM
