Old 08-05-2006, 01:11 PM   #1
addicted2speed
addicted2speed's Avatar
Drives: Yaris 3door Lift Back
Send a message via AIM to addicted2speed
Speakers and Systems???
I don't know much about wireing and all that but I was wondering if you can wire nicer speakers to the stock radio plate? I'm new to this, please help me out
Getting my Yaris in about a week!!! Can't wait
addicted2speed is offline   Reply With Quote
Old 08-05-2006, 01:29 PM   #2
plushDJ
Drives: 2007 3 dr manual
Yes, you can............................................... ..
plushDJ is offline   Reply With Quote
Old 08-05-2006, 01:50 PM   #3
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
The stock speakers are really pretty crummy. The factory radio/CD isn't half bad. Decent speakers are fairly eady to intall (if a little time consuming) and make a huge difference in sound.
Old 08-05-2006, 03:18 PM   #4
ChinoCharles
Drives: LB
Honestly, adding speakers to the factory head unit will make only a marginal difference without adding an amp to power those speakers. Something to think about...
Old 08-05-2006, 04:49 PM   #5
addicted2speed
THANKS GUYS! I really appreciate it! Now is this a hard install especially with the amp? Music is BIG for me so I need it to sound as awesome as possible!!!
Old 08-05-2006, 04:51 PM   #6
ChinoCharles
Drives: LB
Installing speakers alone = relatively simple.
Amp = not so much
Old 08-05-2006, 06:59 PM   #7
Violin
Violin's Avatar
I disagree. I installed MB Quart component speaker with the factory head unit (and put sound damping/insulation all around) and the difference is significant.
The factory speakers are simple paper cones and sound very muddy.
The new ones give me very clean (if not terribly loud) sound.
I have a head unit ready to go in, I'm just waiting for an install kit so I plan to do more - but the speakers alone were worth doing.
You might consider installing the speakers on your own and paying someone to install an amp. You can really make a mess of things if you get in over your head.
Old 08-07-2006, 10:47 AM   #8
Alexandre2k3
Drives: Yaris liftback
installed my audiobahn amp in thirthy minutes becuase it was so easy, there is already the decent size hole under the passenger side to run power wire, and grounds wire was convient too. You should do it yourself, better than tursting others with an easy job.
Alexandre2k3 is offline   Reply With Quote
