#1 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
DIY Thai Vios Sports Grill
It's been a while since I installed it, so I'm going to try to remember everything step by step. Sorry in advance if I forget something. Here it goes (stupid hackers):
I forgot how long it took to install, but I just remember it longer than it should have since I ended up cutting myself. Tools needed: - Philips screw driver - Box knife - Dremel (will make it easier, I didn't use one tho since I didn't have one) - Water (might get dehydrated) - Ratchet wrench with (I forget what size sockets) Before: ![]() Step one: Jack the front of the car up. Unbolt these bolts from the bumper in the wheel-wells. ![]() Step two: Remove these pop-in/suicide screws (what ever they're called) from the top of the bumper. I used a thin flat head and gently pried them off in a circular fashion. ![]() Step three: *Read text in pic* ![]() Step four: *Read text in pic* ![]() Step five: *Read text in pic* ![]() Not a step, but just showing the damage that the concrete block on the freeway caused: ![]() Showing the locations of the clips (except the side clips) ![]() ![]() ![]() ![]() ...continue... Last edited by Kaotic Lazagna; 01-05-2009 at 10:16 PM. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Sedan Join Date: Oct 2008
Thanks i have my grill thats been sitting in my garage for the longest time. Nows some motivation go go out and install it hehe
#3 |
Step six:
*Read text in pic* ![]() Step seven: *Read text in pic* ![]() Step eight: Gently remove stock grill off of the bumper. ![]() Comparison pics: ![]() ![]() *Top is the mesh, bottom is the OEM one* ![]() *Also note how the mesh grill doesn't have the screw mounts that the OEM one has*
#4 |
Step nine & 10:
I shave down the tabs on the mesh grill since they were waaaay toooo big to fit in the slots. I also made some of the slots bigger to accommodate the tabs. I used a box knife to do all of this, but I think a dremel will work wonders on the tab. Using some force/coercing, push the tabs into the slots. *****************IF YOU'RE USING A BOX KNIFE OR SOMETHING SIMILAR, BE REALLY CAREFUL. I cut my thumb in the process, and that took some time to clean up and bandage off.*************** ![]() Showing the trimming on the tabs and the slots. ![]() ![]() Be careful to not too much force, or else the tab might snap. ![]() It started to rain a little (and started to get dark), so...
#5 |
Step 11:
*Read the text in the pic* ![]() Step 12 & 13: Put the bumper back on, and screw in all the screws, and push in the pop-in screws. If you have foglights, plug them back in before you put the bumper back in. *I was pressured in time, so I didn't take pics of this* ![]() Step 14: Step back and look at the difference it makes. ![]()
#6 |
#7 |
Drives: lil red 5-door Join Date: Sep 2006
wheee thanks for putting this back dude
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#8 |
#9 |
![]() ![]() Drives: yaris Join Date: Oct 2008
Hey jw, Does garm still sell these grills ?
Tried looking on the website for them, but they weren't on there. did i miss out? :\ |
#10 |
#11 |
![]() ![]() ![]() Drives: Flint Mica Sedan Join Date: Oct 2008
did you buy it pre-painted?
#12 |
![]() ![]() Drives: 2007 Silver Toyota Yaris Sedan Join Date: Jan 2007
where can i get one of these grilles?
#13 |
#14 |
Contact Garm (Cali Yaris) to see if he has any more sports grill in stock. http://www.yarisworld.com/forums/forumdisplay.php?f=56
#15 |
Grille
Just wondering where and how much you got your grille
#16 |
![]() Drives: toyota yaris sedan 07' Join Date: Aug 2009
i bought one of those mesh grills from microimage which i paited it myself, my yaris color is flint mica and i painted the grill black and chrome, not bad!!!! i'll post some pictures.
#17 |
and having trouble installing the grill, this post will help me alot.
thanks kaotic lazagna!!!!! |
| New grille or not | free297 | Cosmetic Modifications (Exterior/Interior) | 27 | 11-14-2010 04:21 AM |
| DIY: Yaris Hatch grill block/air dam | yarswiss | DIY / Maintenance / Service | 0 | 10-26-2008 07:52 PM |
| Vios Grill | Kaotic Lazagna | Cosmetic Modifications (Exterior/Interior) | 32 | 09-23-2007 02:14 AM |
