Old 12-30-2008, 06:58 PM   #1
l.3011
Drives: yaris
head-unit installations
hey guys, im new to these forums, im not sure if this is the right section.
i just needed help with afew problems i'm having.
i've read up on how to do it yourself. got most of the info of this site. and i've previously installed headunits for a number of cars (for friends) yet this one has got me thinking.
ok long story short headunit is in. playing fine. (also did sub and amp) re-wired everything. nicely. only thing is...that wen you go to turn on your headlights...(the center lights with all the temps. a\c things and also the gear box lights) dont seem to turn on. i ran my fingers double checking over everything. fuse's. the only thing i can think of now is if i have the wrong ground connected. would that affect those lights?
any help would be great. i've also researched the wiring diagrams as well so i will double check everything.
btw. its a 08 yaris also 4door hatch.
l.3011 is offline   Reply With Quote
Old 12-30-2008, 09:25 PM   #2
Check your HU's dimmer connection. It sounds like you are pulling down the dimmer output.
Old 12-30-2008, 11:55 PM   #3
futdechenes
Drives: yaris
Also make sure you have enough juice for all that lol.
futdechenes is offline   Reply With Quote
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
Factory Head Unit Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 6 05-11-2007 07:55 PM
Does the non integrated head unit do any processing? ponieswhee In Car Entertainment + Electronics (audio / video / alarm) 1 05-07-2007 09:00 PM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
