Old 01-02-2009, 10:53 PM   #1
jeftwithatee
Drives: yaris sedan 2007
amp under the driver seat
I just want to share my diy project. I am not an expert with car audio, i just learn almost everything in this forum. thanks to everyone who always share their diys, thats a great help. heres some pix:
jeftwithatee is offline   Reply With Quote
Old 01-03-2009, 01:29 AM   #2
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
WOW! That is a damn good looking install... my amp is just sitting under the pass seat with wires everywhere. I've been wanting to properly mount it and clean up the look and keep it from bouncing around, but I've been procrastinating for about a year now. I really like what you did, it inspires me!
wsladaritz is offline   Reply With Quote
Old 01-03-2009, 02:48 AM   #3
yap. very good install.
but note: i think the fuse should be as close as possible to the battery.
Old 01-03-2009, 02:53 AM   #4
YarisSedan
Drives: 08 Yaris Sedan
Also makes it easier to check the fuse too if it blows so you dont have to remove the seat to replace it =)
Old 01-03-2009, 04:18 AM   #5
jeftwithatee
tnx for that guys.. actually i have a fuse near the battery. that one besides the amp is like a sort of circuit breaker similar to what we are using at home. coz am afraid i might blew up the whole thing so i install that one. and if i want to add another amp or if i need to power something i've got one slot ready...
Old 01-03-2009, 05:48 AM   #6
Ferret_san
Hack.... What hack ??
Ferret_san's Avatar
Drives: 07 YR
That's a great install jeftwithatee.
Thanks for posting the pics and welcome to the forums.
Hope you didn't do that install with a few dark & stormy's under your belt
Ferret_san is offline   Reply With Quote
Old 01-03-2009, 06:09 AM   #7
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
good job on the fuses. My only concern is that you might want to go with a lower rated fuse. I couldn't tell if that was 4awg or 8awg you had going to the amp on that distroblock/breaker.
It looks like 8awg in & out. In which case a 30amp fuse/breaker would be much safer.
If you had 4 awg in, and then 4awg out... 60amp is fine
If you are using 8awg at all, in or out, that might be unsafe to have the fuse/breaker set at 60.
There are calculators to find out for sure if it is safe or not. Just google a site called Basic Car audio and Electronics. and search for the calculator, under the wire or fuses tab.
Everytime you reduce the size of the wire you should always re-fuse.
Nice looking install.
Old 01-03-2009, 09:18 AM   #8
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
WOW!! Amazing installation! Good job!
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 01-03-2009, 10:11 PM   #9
POORSHA
POORSHA's Avatar
Drives: 2008 LB
It looks great. You might want to put some tape or a cap on The positive and negitive terminals just in case a coin or metal pen or object should fall on these and cause a short
POORSHA is offline   Reply With Quote
Old 01-05-2009, 04:44 AM   #10
jeftwithatee
tnx very much for the comments guys.. i will considered that talnlnky... its a very good advice actually.. i didnt know about that.... its good you giving comments so i can correct my mistake.. tnx again i appreciate it..
Old 03-03-2009, 04:22 PM   #11
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
i did two arc audio amps under the seats here is my pics just for kicks
[IMG][/IMG]
pennyracer is offline   Reply With Quote
Old 03-06-2009, 04:53 PM   #12
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
nice... are those both for speakers? or is one for subs?
Old 03-06-2009, 07:45 PM   #13
pennyracer
boydstir
pennyracer's Avatar
one for each and i changed one of them to a 1000X1 sub amp instead of a 600X1 sub amp all arc audio componets the sytem rocks thats for sure
[IMG][/IMG]
Old 03-10-2009, 09:23 PM   #14
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
[IMG][/IMG]
How much were you charge to make a box like that?
-- Blen
Old 06-30-2009, 10:21 AM   #15
pennyracer
boydstir
pennyracer's Avatar
Thumbs up I WANT TO TRY 4 10" NEXT BUILD MY BOX LOADED $500.00 SUBS COST ALMOST 200 EACH
-- Blen
JUST LET ME KNOW IF YOU ARE INTERESTED I JUST CHANGED THE COLOR LOOK AT IT NOW
THIS BOX IS REMOVABLE IT WAS BUILT TO DO JUST THAT !!! CLEANEST ON HERE IF YOU ASK ME
Old 07-02-2009, 02:19 AM   #16
1NZYaris1
1NZYaris1's Avatar
and Then mine after his ,
Old 07-02-2009, 03:52 AM   #17
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Here is another example.....
fuji is offline   Reply With Quote
Old 07-02-2009, 09:41 PM   #18
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Wow. You fit two amps under one seat?
Driver seat TEHxFALLEN V1.2 General Yaris / Vitz Discussion 4 01-21-2018 04:29 PM
Amp fit under driver seat dlinkwit27 In Car Entertainment + Electronics (audio / video / alarm) 17 10-18-2010 09:14 PM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
Amp install under the passenger seat questions.. MudBug In Car Entertainment + Electronics (audio / video / alarm) 19 06-06-2007 11:12 AM
