Old 01-03-2009, 04:13 AM   #1
YAR1S
YAR1S's Avatar
damp engine problems?
today there was a lot of rain
and i didn't run my car the other day so basically it had been sitting at a slightly declined driveway with the engine pointing down for 2 days without being run and in a very wet and humid climate.
I turned it over and it stuggled to keep running smoothly... so I shut it off.
waited a few minutes outside of the car and could smell a burning sort of smell.
second attempt.... started, ran rough.... then eventually stalled....
third attempt, started, ran rough, rev'd it a little and began to run smoothly.
I poped the hood and noticed that my windshield fluid container was open??? I doubt that had any effect,
ALSO there was some smoke (or steam) coming from the back right portion of the engine...
after a whille it stopped and the car ran perfectly....
I guess the engine just got damp????
Any thoughts?
-Jen <3
Old 01-03-2009, 04:53 AM   #2
kou
Drives: 08 lb
the only thing i can think of is you belt got wet and was slipping so the alternator wasnt giving enough juice to the motor.
Old 01-03-2009, 05:34 AM   #3
YAR1S
YAR1S's Avatar
ah that could make sense....
-Jen <3
Old 01-03-2009, 06:27 AM   #4
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
the washer fluid resevoir cap works well only if you make sure it **SNAPS** when you close it sucker seals tight.....if you just kinda flap it close and it clicks or something it will pop right back open....
I swear I've typed this before....deja-vu.....weird....I think I need to go to bed....
but nope the fluid won't come sloshing out....
most likely culprit was very small amounts of condensation forming in the fuel lines and causing a partial combustion event in the chambers ( I say this as the car was not run for what, two days, right?)
Old 01-03-2009, 06:40 AM   #5
YAR1S
YAR1S's Avatar
yep not run for two days... and a lot of rain in the last two days.
-Jen <3
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 08:48 AM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 09:02 AM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 07:17 PM
