Old 01-04-2009, 08:14 AM   #1
letstry1234
Drives: 2008 Yaris liftback Red
so can you turbo the yaris without check engine lights?
OK. I have a Audi TT, I have done a fair amount of mods to it, I understand the hardware side of it. but without a ecu hack (which doesn't exist ,right) how do you get by the ecu? I don't seem to have a grasp on it thanks for explaining
letstry1234 is offline   Reply With Quote
Old 01-04-2009, 02:49 PM   #2
seth_man
seth_man's Avatar
Drives: 08 Liftback
Without tuning, you would need to get the injector size and fuel pressure absolutely perfect for the boost you plan to run. it would take some math and most likely some trial and error before you got it right but yeah it could be done.
seth_man is offline   Reply With Quote
Old 01-04-2009, 03:35 PM   #3
it also helps that the base tuning actually runs quite rich at WOT...
Garm (cali yaris) has been having a lot of difficulties getting a piggyback to work so has been running his 183hp turbo'd yaris on the stock ECU for several months now. Of course, he's not driving balls to the wall all the time, but the stock tune seems adequate so far!
Old 01-04-2009, 04:12 PM   #4
letstry1234
so what injectors are people using? and fuel pressure regulator?
Old 01-04-2009, 05:58 PM   #5
"People" aren't doing anything. Yet. I think there are three or four of us only that have tried turbo-ing in this country so far. Me, Cdjyded, Richard Holdener and one other. No one has successfully and completely tuned the project and run it on the street with no issues yet.
to answer your question (doing some searches on here would probably benefit you), I'm running tC injectors and not FPR, the fuel pressure seems to be just fine up to 8psi.
Old 01-04-2009, 06:02 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
same setup i have at 10psi, no fuel pressure issues (not that you could correct it anyway, without re-plumbing the fuel system)
i live with the CEL on a daily basis...
Old 01-04-2009, 06:24 PM   #7
kou
Drives: 08 lb
what is the cel that you are getting and what year tc injectors(not sure if they are all the same)thanks.
Old 01-04-2009, 07:05 PM   #8
tC injectors havent changed. The CEL I get is 0172, which is interesting because that is too rich!
Old 01-04-2009, 07:18 PM   #9
kou
Drives: 08 lb
thanks.did you ever run the car on stock injectors.
Old 01-04-2009, 08:53 PM   #10
nope, haven't tried that!
Old 01-04-2009, 09:04 PM   #11
kou
Drives: 08 lb
the only reason i ask is i am planning on getting the zage turbo kit,once the RH intake manifold comes out and thinking an extra injector may be best to turn on when needed instead of having the bigger injectors on all the time.
Old 01-05-2009, 01:07 PM   #12
saplaymate
saplaymate's Avatar
Drives: 08' HB
"People" aren't doing anything. Yet. No one has successfully and completely tuned the project and run it on the street with no issues yet.
[B]! ! ! I MUST DISAGREE ! ! !
I have been racing around FULLY TUNED , for 30K miles now.
10psi , 2zz Lotus injectors (330cc) , rest of the fuel system stock !
ZERO ISSUES anywhere in the power band. [/B]
0 - 60 in 3 shifts
saplaymate is offline   Reply With Quote
Old 01-05-2009, 01:19 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
i don't think you understand how injectors work.. and considering you can get tC injectors for free generally, it's a win/win
Old 01-05-2009, 04:52 PM   #14
kou
Drives: 08 lb
whats to understand an injector turns on and off if you have a bigger one it releases more fuel.so a free cold start injector from an older VW would probaly work better to turn on when needed than four bigger injectors running all the time.
Old 01-05-2009, 06:03 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
larger injectors open for less time... it's called duty cycle.. you can run 550cc injectors as long as your pulse width is short enough
Old 01-05-2009, 06:38 PM   #16
Did you get the "in this country" part?? -- which I still believe is true. sheesh.
Old 01-05-2009, 08:00 PM   #17
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
How many cc's are the stock injectors and the TC injectors?
Old 01-05-2009, 08:01 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
tc injectors are 360-370 iirc..
stock is like 210? i forget lol
Longest time you left your Yaris engine running iwantayarisnyc General Yaris / Vitz Discussion 35 12-17-2008 10:07 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
