Old 01-06-2009, 12:42 PM   #1
SweetRS
Drives: 2006 Yaris Rs
Video on while driving
im trying to figure out where to put the wire that allows me to watch from my dvd player while the ebrake is engage....but i want to bypass that by puting the wire somewhere other than my ebrake switch, anyone know where a good place would be ???
SweetRS is offline   Reply With Quote
Old 01-06-2009, 01:16 PM   #2
mastaofdisasta
mastaofdisasta's Avatar
Drives: yaris
Why do you want to watch dvds while you drive?
ballin on a budget.
mastaofdisasta is offline   Reply With Quote
Old 01-06-2009, 01:24 PM   #3
SweetRS
more for the passenger than me...i do long drives.
Old 01-06-2009, 01:40 PM   #4
jar73186
jar73186's Avatar
Drives: 1984 Toyota 4-Runner
Run it to a switch under the dash. What stereo/dvd player is it?
Adam
jar73186 is offline   Reply With Quote
Old 01-06-2009, 01:45 PM   #5
SweetRS
clarion max385vd... are there more switch's under the dash or do u mean an external switch?
Old 01-06-2009, 02:03 PM   #6
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
just connect the brake wire from the HU to the black ground wire in the harness..voila!
it just needs to be grounded.
Old 01-06-2009, 02:07 PM   #7
SweetRS
That didnt work, tried that already.
Old 01-06-2009, 02:12 PM   #8
jar73186
jar73186's Avatar
Don't run voltage to it. I believe that the wire is a ground switch, i.e. you need to run the wire to a ground then back to the switch. Leave the switch open, when you start the car hit the switch which should ground it out, I need to make sure that is correct for all clarion units, There is another way to do it with the remote but I can't find the code. I am trying to get ahold of a friend of mine that we installed a clarion stereo/dvd in his truck. We wired a switch in it to the ground. Let me see what I can find.
Adam
Old 01-06-2009, 02:14 PM   #9
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
thats weird .. worked on my HU
Old 01-06-2009, 02:14 PM   #10
SweetRS
Thanks guys, i appreciate the help
Old 01-06-2009, 02:20 PM   #11
SweetRS
some HU's are different and require different connections to bygpass. is yours a clarion?
Old 01-06-2009, 02:31 PM   #12
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
nope..some chinese one from ebay :)
Old 01-06-2009, 02:35 PM   #13
SweetRS
yeah, i tried grounding to the ground wire from the HU , i tried grounding it to a bolt in the floor behind the shifter, and a bolt in the dash behind the HU, right now im just tapped into the ebrake, but, i might just hook up a switch. unless theres another way possible!
Old 01-06-2009, 03:01 PM   #14
jar73186
jar73186's Avatar
http://www.fixya.com/support/r515002...g_break_bypass
Try that, I talked to my friend he said he would try and find out the write up he found. He did say that not all of the Clarions will accept the codes so you may have to run the switch. I googled it and that's the most info I got on your stereo.
Adam
Old 01-06-2009, 03:04 PM   #15
SweetRS
thank you for looking into that for me.
Short test video, my first to YouTube LtNoogie Photo-Video-Media Gallery 17 12-22-2008 12:44 PM
Test Video in Berkeley... explicit lyrics Vanderkitten Photo-Video-Media Gallery 13 06-27-2007 05:13 PM
Driving car at 75mph on position 3 :( hans_fh General Yaris / Vitz Discussion 22 04-03-2007 04:09 PM
Fast and the Furious Video Game Contest BulletProofAuto Off-topic / Other Cars / Everything else Discussions 5 10-14-2006 03:14 PM
driving harsher..... hoahmaru General Yaris / Vitz Discussion 7 04-09-2006 02:59 PM
