#1 |
For the last year I have noticed a strange whinning sounds come from the belts of the engine, and when I paid toyota some $430 to do the major 30k service, they told me that was fixed, it was not at all actually.
Now in the last week I have noticed a new sound, and this starts with turning on the blower in the car. I have it pointing to the floor only, so I know the compressor is off, but there is a constant sounds of a fan motor like it is dying/chogging along, getting faster with the faster fan speeds. I also noticed and confirmed last night when I left it on and started cleaning the snow off the windows, that the same wierd noise is heard from outside even louder. What in the world could this be? I don't exactly have time to go into Toyota asap, Im doing inventory every night from like 5-5am where I work, and I wont be free till end of the week. Any comments/questions/suggestions appreciated. |
![]() ![]() ![]() Drives: Blazing Blue Liftback Join Date: Oct 2008
It could just be your fan belt is wet. Or the tensioner type thing that holds the belt tight.
#3 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Had this problem with my last car. The belt will make whining noises when it has little or no grease, or when it needs to be replaced. Check the grip side of the belt and look very closely for cracks, which would indicate a needed replacement. If it's still good, then run down to the nearest auto store and pick up a very small packet of serpentine/drive belt grease for a couple bucks. Use the whole packet and pour the grease in even amounts on each pulley. The whining should die off after you drive a couple miles
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#4 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Sedan Join Date: Oct 2008
Spray some lubricant on the belt and see if the noise goes away. Like some WD 40. Noise is gone you know its the belt. Just needs to be adjusted or replaced. And btw there is no major service at 30k Its just a oil change.
#5 |
If you are also talking about your blower in the cabin , making a noise it is probably due to a leaf been sucked into it , or something like that.
#6 |
I dont know if it was 30k or 35k, but whatever my dealership has listed is a major service at that milage. I think I did it late around 40k instead. Either way it was too expensive.
Where is this belt you are all talking about? As soon as I turn off the blower, the noise inside/outside the car stops. And vise-versa. Any pictures please? Its freezing over here for me to take a guess. Thank you. |
#7 |
Your blower is a direct drive electic motor, no belt, unless you are meanning aircon belt . does the blower make the noise with the aircon off,
but blower motor still running. |
#8 |
Yes, it makes the noise whenever it wants too, mostly when the car is really cold, or has been running for a while, its not a pattern, just does this randonly, but when it starts, it doesnt stop until I go to the car the next time if Im lucky, like last night it made the noise all the way home from work, but just now it did not make any noise.
And I only use the heater with the air blowing at my face/floor or just at the floor. And the A/C is OFF! So this probably means something is stuck, or the blower is dying? |
#9 |
More than likly something is in the blower, remove panel under steering wheel
and you should see the blower to you right . Remove inspection panel (where filter is mean't to go ) and check for obstructions. |
#10 |
![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
I don't know what model Yaris you have, but the blower in my HB is right behind the glove box. Just yank out the whole box, and there it is!
#11 |
passengers or drivers side
so many of them
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Passenger side for LHD cars. Bottom glove compartment pops out when you squeeze in the sides.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#13 |
The type of car I have is under my name!! 2007US Sedan. I hear the noise more from the right side, never tried opening the glove compartment while the noise was happening, I wonder if it would get louder.
And also, how do I get inside the blower itself once I get to it? I see something in the picture that looks something like a handle, but I dont know what it is! I will try this later as its freezing here and Im very sleepy. |
#14 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
my blower fan makes noise. it's normal.
#15 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
it is easy for pine needles and small leaves to get in the housing and once in they make all kinds of noise.
#16 |
Oh, ok, but its very annoying, I hear it even with the radio on. NEVER did this before, now its constant.
My belts on the other hand also make a wierd noise, and get high pitched when the engine is warm/hot. Toyota told me they fixed that, but they did not since it made the same that same day leaving the lot. I should have left the car again, oh well, had to go to work. Im not always free. Had 2 jobs and school full time. Now its 1 job and school, still doesnt mean I can go in whenever. :( |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 31 | 10-20-2025 10:08 AM |
| Car doors are not self-locking when left unlocked | fainty_girl | General Yaris / Vitz Discussion | 27 | 03-14-2011 10:12 AM |
| Someone Please Help With SET & Local Dealer Nightmare! | sanityassassinv2 | General Yaris / Vitz Discussion | 32 | 11-26-2008 12:32 PM |
| 11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) | Jerkratt | NY / NJ/ CT / PA | 14 | 10-26-2008 06:51 PM |
| big older car vs little newer car | xed | General Yaris / Vitz Discussion | 9 | 09-16-2007 05:35 AM |
