Old 01-12-2009, 12:20 PM   #1
TWEAKED_ICE
TWEAKED_ICE's Avatar
Drives: Scion tC
Pioneer Avic-D3 VSS wire problem
So, I just installed an Avic-D3 on my girlfriends 09 Yaris-S, tapped the vss wire to the purple wire via instructions found here on yarisworld.... but, there is no signal coming through. Is it differenent on the 09? I would assume not, but I'm willing to try anything at this point.
Used this for reference:
Any suggestions?
http://www.tweakedice.com
TWEAKED_ICE is offline   Reply With Quote
Old 01-21-2009, 02:57 AM   #2
TWEAKED_ICE
Drives: Scion tC
Any help?
Old 01-21-2009, 07:39 AM   #3
I'm not sure myself, really... What I do know is that between 07 and 08 the tach wires changed color from green to orange, so it is possible the VSS as well. If you can't match the wire color, maybe try looking up the actual pin location, that should remain the same.
Old 01-21-2009, 08:49 AM   #4
The easiest place to grab VSS is at the TPWS connector (behind the lower passenger glove box)
TPWS location:
VSS wire location:
Old 02-12-2009, 01:03 PM   #5
TWEAKED_ICE
Drives: Scion tC
perfect! thank you for that, i'll try it out!
Old 08-16-2010, 05:30 PM   #6
ali077
TRD TURBO
Drives: TRD VITZ TURBO 2003
i need help plz... i drive a vitz trd turbo 2003. ive installed a pioneer vdp and i need a speed signal wire for the vdp to work. any1 can help?
ali077 is offline   Reply With Quote
