#1 |
![]() ![]() Drives: magntic grey Join Date: Dec 2008
steering wheel outta control when im coming to a stop
i just switched over to 205/15/50 from stock
everytime i slowly come to a stop at a crowned intersection its seems like my steering wheel has a mind of its own. the stock wheels felt alot softer and more on control. will the wider tider affect my suspension in the long run? should i switch to 195 or will 205's be ok.>? i wanna keep my rims what can do fix this? btw im planning to lower around 1.5 inches later on. i suspect its gonna get worse. |
What tire did you go with?
Been a long time messing with cars.. |
#3 |
205/50/15 on 15x7 alloys
#4 |
Drives: lil red 5-door Join Date: Sep 2006
I think he also means, what brand and model?
Also, I noticed the power steering can do some weird antics if the pavement is not so smooth, is that the case?
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#5 |
i found similar things on my XRS when i had 235 tires on it....it would track the grooves in the road a bit more....
youll be ok w/ 205's you just need to compensate more because of it when the road isnt so smooth
#6 |
Drives: 2014 White VITZ Join Date: May 2007
205mm tyres are a great fitment for our cars. No worries there. But, occasionally it's just the tyre's tread design that makes the car do squirrelly things. What tyres are you running?
#7 |
![]() ![]() ![]() Drives: Toyota Yaris 1,8 TS 5dr. 2007 Join Date: Dec 2008
Hi
When the tyres are wider and the profile is lower you will get a more direct feeling. Especially if it´s a very hard tire you are using. Did you try to squeez the tyres before they were mounted on the rims? Regards Steven. |
| Mesh Steering Wheel Cover... Toxic? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 20 | 07-03-2010 05:53 AM |
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| audio volume control on steering wheel | hans_fh | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 01-04-2009 09:07 PM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 01:05 AM |
