Old 01-26-2009, 01:08 PM   #1
andries
aka Jack Wolfskin
Send a message via MSN to andries
throttle response
can someone tell me or the throttle response is to chance through the OBDII connection. (I do not know if your cars have a electronic throttle but my Yaris have)
andries is offline   Reply With Quote
Old 01-26-2009, 04:02 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I noticed a center arm rest. How do you like it? Is it high enough? Where did you get it?
Old 01-26-2009, 04:41 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yes. As far as I understand, the yaris has a DBW (drive by wire) throttle, which means that when I press the accelerator, it sends the value to the ECU first, and then the ECU sends it to the throttle.
There's a Blitz throttle controller out there that supposedly modifies the throttle curves and apparently works great if you want to get better response.
I went with lightweight NST pulleys, and the throttle response is awesome...
Old 01-26-2009, 06:45 PM   #4
NonStopTuning
NST Pulley Kit = MUCH better throttle response!
MIKE @ NST
www.NonStopTuning.com
Old 01-26-2009, 08:10 PM   #5
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
There is a Sprint Booster made by a Greek company. It plugs into the accelerator socket and thus modifies the signal from there.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 01-27-2009, 11:19 AM   #6
andries
aka Jack Wolfskin
Thanks for the reactions.
I read the NST Pulleys are the best solution.
Old 01-27-2009, 11:20 AM   #7
andries
aka Jack Wolfskin
Awesome
E-bay
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
1zzfe throttle body lilman717 Performance Modifications 22 02-12-2009 07:08 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
10" Type R in TCAB - Freq response - vid spkrman In Car Entertainment + Electronics (audio / video / alarm) 3 03-20-2007 03:53 PM
