Old 01-26-2009, 06:08 PM   #1
JapRulezz
JapRulezz's Avatar
Drives: yaris sedan 2NZ-FE
-----> DENSO VS NGK
my car comes with normal cheap 20 K denso spark plugs
and i think that changing to iridiums would spice things up a little
theres the denso iridium power
and theres the NGK IX iridium
so which one is better?
JapRulezz is offline   Reply With Quote
Old 01-26-2009, 09:38 PM   #2
Marfulion
Drives: 2008 Yaris Sedan
i had the ngk iridium plugs in a bike a had, it really made a difference, the throttle fealt so crisp n clean, not sure if it would make a noticeable diff in a car though. i myself would like to know if they would
Marfulion is offline   Reply With Quote
Old 01-27-2009, 02:18 AM   #3
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Both brands are OEM for Toyota.
Some Yaris come with denso and some with ngk. You can't go wrong with any of them... If there is any difference between those you won't be able to feel it.
Denso's are usually more expensive.
Old 01-27-2009, 04:24 AM   #4
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Old 01-27-2009, 06:54 AM   #5
Black Yaris
der Zeck
Black Yaris's Avatar
Both brands come out of the same NGK factory, Denso just has theirs relabled
same thing for Autolite and Motorcraft
NGK also makes all the IR plugs for Delco as well
Old 01-29-2009, 10:06 PM   #6
botchilah
Drives: white and red shiny things
Problem with Iridiums plugs in general is that if you do a lot of idling, short drives, starts and stops, the plugs foul far easier. And they cost a lot too compared to regular plugs.
But the power gains of Iridium plugs are definitely true from my experience. I've seen a lot of logged dyno runs on turbocharged cars that switched from regular plugs to iridium oes and you'll see a smoother power curve, with the iridium equipped cars picking up the odd 2-3, sometimes even 5hp everywhere along the curve.
botchilah is offline   Reply With Quote
Old 01-30-2009, 08:18 PM   #7
JapRulezz
JapRulezz's Avatar
so basically there the same , so it wont make a difference
ok how about the splitfire brand is it good?
and should i use spark cables as well , or stick to my ordinary ones/
Old 01-30-2009, 09:16 PM   #8
Black Yaris
der Zeck
splitfires are just a cheep plug, I would never put them in anything I own
our car does not have spark plug cables, it is a coil on plug design
FS: OEM NGK Spark Plugs mikenacarato Items for Sale by private party 13 01-23-2009 04:05 PM
C2AUTO presents --> WORKWORKWORKwheels! C2AUTOSPL Sponsors Classifieds Area 29 09-26-2007 12:35 AM
How long? Japan --> US KittenRD New YARIS Purchase Forum 4 05-30-2007 08:13 AM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
6CD mp3 changer -> continue the song instead of restarting the track? nonopeno In Car Entertainment + Electronics (audio / video / alarm) 8 11-05-2006 10:52 AM
