Old 02-24-2006, 11:43 PM   #1
rog442
rog442's Avatar
Drives: 2006 Toyota Yaris
Question Idle RPM
Hi there,
When the engine is warm on my Yaris, my RPM goes up and down between 650 and 500 RPM and at 500 the whole car shakes, so iIt creates this intermittent shaking. Toyota says that these are normal idle speeds.
Has this happened to anyone else?
rog442 is offline   Reply With Quote
Old 02-25-2006, 01:29 AM   #2
swng
swng's Avatar
Drives: 06 3-dr auto RS
No. Seems I am lucky again. I think if the car shakes, the idling speed is not normal.
swng is offline   Reply With Quote
Old 02-26-2006, 07:31 AM   #3
jcove
jcove's Avatar
Drives: 2011 Rogue
My RPM's are about the same, but I haven't had the problem you're seeing here. Could be the time of year. I'm not sure what the weather is doing where you are, but it's up and down here, which can cause moisture in the gas and cause a little bit of issues. Plus the gas in winter is actually mixed a little different so when it's warm, the car won't run as well.
jcove is offline   Reply With Quote
Old 02-26-2006, 04:13 PM   #4
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
I think you should bring your car back to the dealer to check. Vibration is normal, but not shaking.
GabL is offline   Reply With Quote
Old 02-24-2011, 01:12 PM   #5
Kitt
Kitt's Avatar
so what is the average idle speed with a warm engine?
Old 02-24-2011, 03:27 PM   #6
Vinceb
Drives: 2008 5 Speed Sedan
when warm mine idle's at around 500-700 anywhere in there. when my battery was dead and the engine had to re-learn everything it was dropping to 450 and at that point there was a small shuttering but nothing too bad.
Vinceb is offline   Reply With Quote
Old 02-24-2011, 03:35 PM   #7
yaris2010RS
yaris2010RS's Avatar
how many km on ur car? its an 06 so could use a tune up
Old 02-24-2011, 03:38 PM   #8
LOL @ 5 year old post
Old 02-24-2011, 03:41 PM   #9
yaris2010RS
lol, my bad, kitt started it
Old 02-24-2011, 03:43 PM   #10
Yes, but with a new question. You actually responded to the OP!!! ROFL
Old 02-24-2011, 05:56 PM   #11
swidd
Drives: Yaris HB
Isn't it something about the cooling fan starting up, or some compressor thing turning on and off to control heat? I had the same problem when the car was new... its kinda just gone away with some cleaning of MAF, new air filter etc... probably unrelated.
Old 02-24-2011, 06:17 PM   #12
matthewai
matthewai's Avatar
Drives: it is kinda stock
mine actually does this sometimes just the rpm flux not the shaking but i think it only happens when i have the heat on so ill have to do a test some time
Shifting RPM GabL DIY / Maintenance / Service 10 08-06-2006 05:40 AM
