Old 02-01-2009, 02:33 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Wide rubber on a Yaris (pic inside)
below you see 245/40/17 on a 17X7 +35ET wheel, lowered on Tanabe DF springs
Old 02-01-2009, 02:33 PM   #2
ChinoCharles
Drives: LB
DAYUM.
Old 02-01-2009, 02:36 PM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Nice work, that looks good.
Old 02-01-2009, 02:38 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
and I thought my 225/50R15's +38 were the max you could stuff under there
Old 02-01-2009, 02:40 PM   #5
should be ok as long as the yaris doesnt need to turn, lol
Old 02-01-2009, 02:41 PM   #6
ChinoCharles
Drives: LB
LOL, all you see is Tamago leaning around inside trying to drive it like its a gixxer.
Old 02-01-2009, 02:44 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
AGREED
we just test fit them for the fun of it. they fit without rubbing on my xA but..... not gonna happen on a yaris
Old 02-01-2009, 02:54 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
this is forum member THEREALENTH's car by the way
Old 02-01-2009, 05:33 PM   #9
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
pimpin ;D
Its a Chao!!!
Old 02-01-2009, 09:19 PM   #10
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
looks nice.. Cant wait till my wheels get here 17x7 with 215/45/17 Sunny sn3800 tires :D
Arkhangel is offline   Reply With Quote
Old 02-01-2009, 09:21 PM   #11
Black Yaris
der Zeck
don't think that is going to fit very well Arkhangel, if you are lowered
Old 02-02-2009, 12:17 AM   #12
TheRealEnth
Beast
check it
Its a Chao!!!
Old 02-02-2009, 12:19 AM   #13
johnnypaseo
Drives: Toyota paseo
Dang that looks hella sexy hows the rubbing? minimal?
Old 02-02-2009, 12:28 AM   #14
TheRealEnth
Beast
it is not recommended to be done on a yaris, it was just a test ;D
Its a Chao!!!
Old 02-02-2009, 06:57 AM   #15
dinamix
Drives: magntic grey
is it possible to run these on the rears of my yaris since im not turning on the rears? im on a 1.5 inch drop..
my buddy has a spare set of 255/40/17 laying around in his garage..my wheels are 17x7 offset +42..i was thinking 255/40/17 on the two rears and 205/40/17 on the fronts..I wanna give it the muscle drag car look
dinamix is offline   Reply With Quote
Old 02-02-2009, 07:00 AM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
if you have ABS i don't recommend running different tire diameters on different ends of the car.
and the rear will take some massaging to make a 255 fit. you'll HAVE to add camber shims. the rear has less clearance than the front (Russeltehpirate, chime in here please)
Old 02-02-2009, 07:39 AM   #17
dinamix
thanks for your help man
yeah..no abs..i have the base model
the camber shims issue is a good point..ill probably be ruining the suspension geometry in the long run..i notice running camber kits/shims is pretty common with the wide wheel slammed vw golf guys..but if the can do it why can"t we?
should i stick to my 205/40's for now?..those A032R's are so damn tempting..
btw those tires look awesome..do you have a side view of the car?..
Old 02-02-2009, 08:42 AM   #18
griiiiiip!
Light inside Yaris. Twistoffate0817 General Yaris / Vitz Discussion 5 12-28-2008 10:21 AM
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 08:27 PM
