Old 02-03-2009, 12:44 AM   #1
buchieboy
Drives: Toyota Yaris
TIRE Replacement
Guys, i know nothing about wheels..
My stock tires are the 185/60/15 Yokohoma tires.
Can i change it with the ff sizes and still use the same stock rims?
195/60/15
205/55/15
Any 16" tires
Also, what are the advantages/disadvantages of tires above?
buchieboy is offline   Reply With Quote
Old 02-03-2009, 02:48 AM   #2
Ryu
This is one of the website that you can play around with the tire spec to see will it fit.
Try to stay within 3%
http://www.1010tires.com/TireSizeCal...?action=submit
Also advantage of 205/55/15 compare to the other one is that it provides wider tire so better cornering, but losing a bit mpg.
195/60/15 narrower width so higher mpg but lose a bit of cornering ability, and 60 give you more rubber so it gives better comfort.
Old 02-03-2009, 07:13 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
You can use either of those replacement size tyres on your stock wheels. For helpful information, check out the "Official Yaris Wheel and Tire Guide" in this section. You'll also find a link to a better wheel and tire fitment calculator there.
http://www.yarisworld.com/forums/showthread.php?t=5021
Old 02-04-2009, 12:52 AM   #4
buchieboy
Thanks Guys!
Also, will any of this wheels fit my stock Rims?
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
