Old 02-03-2009, 03:22 PM   #1
blackvvti
Drives: Toyota Vitz
Steering swap
Hi,
Do you think I will be able to swap the standard steering on the 99 Vitz with a steering from a 2008 yaris (from this image: http://www.toyota.com.mt/bv/1024-gal...image7_800.jpg )? Will the splines that connect the steering wheel to the car's column match? Or any other issues?
Thanks
blackvvti is offline   Reply With Quote
Old 02-03-2009, 04:21 PM   #2
1NZYaris1
1NZYaris1's Avatar
no you can not as the steering wheel internal shape is different
and your stock covers will not fit.
If you want a leather steering wheel go to sparks toyota and look on there web site, look at the xa , xb wheels to 2005 they should fit.
no dobt some one will correct me if i am wrong.
below is twhat a 2008 steering wheel internal looks like compare it to yours.
Old 02-03-2009, 04:45 PM   #3
blackvvti
Drives: Toyota Vitz
Thanks for the reply. Do you think the facelift (mk2?) will have a steering wheel that matches?
On a seperate note is there a way to hide those screws behind the internal door open levers. I find them an eye-sore and as you can see from the above pic they havent been fixed in the face lift version.
Old 02-04-2009, 10:27 AM   #4
this is the steering wheel i like alot! I miss my 1st gen face lift :(
Mesh Steering Wheel Cover... Toxic? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 20 07-03-2010 05:53 AM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 05:52 PM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
