Old 02-03-2009, 08:36 PM   #1
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
My idea about DFCO.
Why can't hitting the brakes activate DFCO or something similar to it?
I'm obviously not a mechanic, or knowledgeable about engines - is there a safety issue related to this, or would the engine just stall?
*curious*
Old 02-03-2009, 09:01 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Generally speaking, most people have already taken their foot off of the gas before they start braking. (because if they've been trained properly, they are using the same foot for the gas and the brake)
DFCO activates anytime you are off-throttle, in gear and the momentum of the car is sufficient to keep the engine turning at more than about 1200 rpm.
Given those two facts... is there any need to involve the brakes in the equation? If you're driving an automatic, DFCO is already activated even BEFORE you start braking, and will stay that way until the engine revs decrease to the point that the engine needs fuel to idle. With a manual, the same holds true until you put the clutch in, then the engine has to exit DFCO mode to idle.
Old 02-03-2009, 09:07 PM   #3
smacky
Drives: 2008 Liftback AT
From what I've observed DFCO will work until your braking reduces your speed and your RPMs get to 1000ish. Braking for a short time (around a second) will also shift you into the next gear down and that way you can keep your RPMs a little higher and DFCO will stay on a little longer.
smacky is offline   Reply With Quote
Old 02-03-2009, 09:11 PM   #4
twowheels
Drives: '09 Meteorite Metallic 3 dr MT
I've been wondering on the manual whether downshifting would help bump the RPMs up a bit to keep it in DFCO mode longer, but since I don't have a tach () I can't really tell. Anybody with a tach and the stock 15" wheels have any idea what speed 1000 RPM is in each gear?
Besides, I don't like using my expensive clutch to slow down, so I probably wouldn't do it anyhow.
twowheels is offline   Reply With Quote
Old 02-03-2009, 09:30 PM   #5
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
This comment puzzles me.
Old 02-03-2009, 10:50 PM   #6
MadMax
MadMax's Avatar
So, does it make sense to downshift the automatic to keep engine decelerating occurring as long as possible? I've gone down as far as second gear on my auto a few times; but I've often wondered, is it putting increased wear and tear on my transmission just to save a few drops of gas?
I gotta admit, this DFCO feature intrigues me and I am trying to maximize its use!
Cheers! M2
Old 02-04-2009, 12:08 AM   #7
Loren
What?
Loren's Avatar
Unless I'm hardcore hypermiling, I don't bother downshifting below 3rd gear on a DFCO coast-down. You can go pretty darned slow in 3rd gear before getting below 1000-1200 rpm.
With an automatic, the transmission will automatically downshift as you decelerate and should keep your revs up until you're at a near stop, anyway.
Old 02-04-2009, 01:35 AM   #8
twowheels
the clutch doesn't slow the car, the engine's compression slows it down. the wear and tear on the clutch happens when you let it out after switching gears
I realized that, but it was a shorthand way of saying that I don't want to wear out the clutch rather than the much cheaper brakes....
Old 02-04-2009, 12:00 PM   #9
Sodium Duck
╚══════════RN
I thought that DFCO turns off when you hit the brakes? I remember reading that somewhere on the forums.
Old 02-04-2009, 12:03 PM   #10
nope, it only turns off when you hit the gas, or the engine gets below a certain speed
Old 02-04-2009, 01:56 PM   #11
Sodium Duck
╚══════════RN
My idea has become a reality. =]
Old 02-04-2009, 02:12 PM   #12
MadMax
MadMax's Avatar
I thought someone with a ScanGauage and an auto said it takes a bit for the transmission to downshift after you let off the gas; hence my manually downshifting to kick the DFCO in sooner. If that is not correct, and all I need to do is let off of the gas, I would like to know...
Cheers! M2
Old 02-05-2009, 09:11 PM   #13
ddongbap
Grats.
Old 02-06-2009, 01:54 PM   #14
CKaelin
CKaelin's Avatar
Drives: 2008 Yaris LB 5 speed
I had 230,000 miles on the original clutch in my old 97 tacoma and I downshifted all the time!
My other ride's a Gixxer!
CKaelin is offline   Reply With Quote
Using DFCO to increase your MPG BailOut Fuel Economy Forum 216 08-30-2018 05:15 AM
DFCO and Autos MadMax Fuel Economy Forum 29 11-22-2008 09:15 PM
Crazy DFCO Idea nsmitchell General Yaris / Vitz Discussion 3 05-26-2007 01:53 AM
I Don't Think My Yaris Has DFCO Kaotic Lazagna General Yaris / Vitz Discussion 27 03-30-2007 06:37 PM
