Old 02-08-2009, 10:26 AM   #1
scottperhamjr
Drives: toyota yaris 4 door base
ways to fit rubbing rims/tires!
i have kobe 18" rims that rub on the inner lip in the wheel well with weight in the back im thinking about cutting out that lip but yet am not sure any suggestions
scottperhamjr is offline   Reply With Quote
Old 02-08-2009, 10:30 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
are you talking the plastic bit?
yeah, trim that piece away if it's rubbing. the insides of my fenderwells up front (metal upper portion) have places rubbed down to bare metal after 4 years of autocrossing on a super wide tire.
bottom line, if the surface you're rubbing on is not harming the tire, you really have no worry of damaging anything.
Old 02-08-2009, 10:35 AM   #3
scottperhamjr
its actually metal if u look at my pic u see the flat black metal just befor the tire well at the bottom edge it bends in to hold strength to the curve of the metal but that 1/2 inch of metal in some spots slams my tires so i was thinking of bending the metal up and flush with the Qpanel or cutting that 1/2inch away...maybe even rolling is a way to go but i dont want to spend money at this time
Old 02-08-2009, 10:37 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
maybe going to the proper tire size would help?
you could probably bend that seam over in the spots that it's rubbing without causing any real damage. a BFH and a punch would do the trick
but yeah, order the correct tire size and that'll help a LOT
edit: looked at the picture again, i don't see any flat black metal
Old 02-08-2009, 10:39 AM   #5
scottperhamjr
yea buying new tires....not an option....what are these tools you are talking about i havnt heard of them. i was thinking of just running a dremmel down and cutting out the entire lip
Old 02-08-2009, 10:43 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
BFH
Big Fuckin Hammer
Punch.. well... that's a punch....
why is running the correct tire size not an option?
what area exactly are you trimming? can you take a better picture?
Old 02-08-2009, 10:46 AM   #7
scottperhamjr
hahahaha yea i didnt pick up on the sarcasim to early lmao...i will get a better pic later but its that inside 1/2 insh lip from the painted sheet metal
Old 02-08-2009, 10:48 AM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
front or back?
Old 02-08-2009, 10:48 AM   #9
scottperhamjr
in the back the front is very very minimal mostly happens on a sharp turn
Old 02-08-2009, 03:30 PM   #10
Yaribhini
I have a fender roller that I used on my other car. Great tool for getting that extra bit of clearance.
Yaribhini is offline   Reply With Quote
Old 02-08-2009, 04:21 PM   #11
it looks like there's a gap in front but it's fully slammed in the back. Stiffer springs would help some. Also, when you say "inner" lip do you mean the part we can see in the picture (which is "outer" to me), or the inside of the tire, towards the center of the car.
Another thing to try might be a camber shim kit in back to get those big wheels to tuck a little better.
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
What can you fit in your Yaris LB that I can't fit in my Yaris Sedan? derickveliz2 General Yaris / Vitz Discussion 42 12-03-2008 12:58 AM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd Bounty Hunter General Yaris / Vitz Discussion 7 07-11-2007 07:40 AM
