Old 02-09-2009, 06:13 PM   #1
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
My idea and your thoughts about it.
Heres the quick & dirty.
The back end of my hatch sags low, too low.
The reason for this is of course all the car audio equipment.
I intend on adding more to the back end so my question to you guys is what route should I go and which which work best.
I want there to be minimal wheel gap but if it means saving money then I can deal with it.
Should I either put 2 of my stock springs back in for the rear or should I try and get a hold of 2 NF210's?
PG TLD22 8V Line Driver
Old 02-09-2009, 06:38 PM   #2
jkuchta
Drives: 2007 Yaris hatch (red)
I'd just go with a set of stock springs.
jkuchta is offline   Reply With Quote
Old 02-09-2009, 06:39 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
get rear springs from an xB. designed to hold more weight. same top/bottom
Old 02-09-2009, 11:15 PM   #4
yarstar
Drives: 2008 Absolute Red HB
I'd get air shocks, or use a set of spring rubbers. If you need a set of spring rubbers, I've got some.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 02-10-2009, 12:14 AM   #5
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Coilovers. That way you can be low, and the ride will be firm.
Saggio is offline   Reply With Quote
Old 02-10-2009, 12:40 AM   #6
kngrsll
Apexing Egg!!
kngrsll's Avatar
i was going to post this, ive been looking at getting some for mine, but for the purpose of raising spring rate... what size did you use? and how did they effect height?
http://www.racingplus.com/coil-over-...ber/1343p10255
here are some for sale, different strengths...
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 02-10-2009, 01:14 AM   #7
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I don't think you should consider going for NF210's since they won't give you more than 0.5" of extra space. I think you should try going back to stock springs in the rear (at least you can give it a shot for free).
