Old 02-12-2009, 01:49 PM   #1
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
What would be ideal?
I am going to get wheels but I can't decide between getting 15x6.5 wheels and put them on my stock bridgestone tires(185/60R15) or get some nice 16x7 wheels and put some nice sticky rubber on them. I am also planning on geting coilovers. It would be cheaper to get some 15's by about $600 however I'd feel safer with better rubber, Opinions ?
I was planning on getting konig feather with some toyo proxies 205/50
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 02-12-2009, 01:53 PM   #2
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
15'S with 205/55'15......
Old 02-12-2009, 01:58 PM   #3
Nagoya_TRD.
Drives: None.
I like the idea of 16s and nicer rubber. If you are going to stretch it, you can go lower too.
Nagoya_TRD. is offline   Reply With Quote
Old 02-12-2009, 03:09 PM   #4
33OH
Drives: '08 Yaris
I have 15x7's with nice rubber (Bridgestone Potenzas) and I love them. I just sold my stock tires off my steelies and put snow tires on them for winter. That way I'm covered all year.
Old 02-12-2009, 03:43 PM   #5
SailDesign
Drives: .
I have 16x7's +42, with 205-width rubber. Love them.
Old 02-12-2009, 05:33 PM   #6
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
If you're going to put coilovers on, I'd suggest a 15x6.5, +40 or higher, with 195/55/15 rubber to avoid rubbing.
• I've had 16x7, +37 with 205/50/16 tires: I rubbed
• I've had 15x6.5, +38 with 205/50/15 tires: I rubbed
• I've had 15x6.5, +40 with 195/55/15 tires: I rarely rub, except under extreme circumstances (hard corners, big dips)
I will not rub with the stock wheels/tire (15x5.5, +45 with 185/65/15 tires)
I am lowered on Megan Racing coliovers, FYI.
Old 02-12-2009, 05:41 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
15X7, +35, 205 55 15 Hankook RS2's or Falken Azenis RT615's and call it a day.
ohh or this!!!
http://www.949racing.com/index.asp?P...ROD&ProdID=178
Old 02-12-2009, 07:58 PM   #8
Thirty-Nine
Maybe on an xA ... but you'll rub all day on a Yaris.
Old 02-12-2009, 08:20 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
so?
fix it.
why are yaris owners so afraid of a little rub?
Old 02-12-2009, 08:29 PM   #10
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
so?
fix it.
Haha, totally agree with you on this. Rub a little plastic and they feel like their car is going to fall apart.
I would get 15s and ditch the crappy stock rubber. Better rubber selection going with 15s. But 16s do look better on the Yaris's round bubbly body.
FunctionSpec is offline   Reply With Quote
Old 02-12-2009, 11:07 PM   #11
Thirty-Nine
so?
fix it.
I guess I don't use "rub" and "ideal" together. He said "ideal."
Perhaps the OP should define what he means by ideal, since everyone has a different opinion.
Old 02-12-2009, 11:12 PM   #12
ChinoCharles
Drives: LB
so?
fix it.
Dude, rubbing is teh suck. Admit it.
Old 02-13-2009, 06:49 AM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
when you guys say "don't buy a +42 offset, you'll rub... you have to buy a +43 offset" does that 1 millimeter make THAT much of a difference? and where is the tire rubbing anyway? outside fenderwell?
Old 02-13-2009, 06:52 AM   #14
33OH
Drives: '08 Yaris
Depends on if the 1 millimeter puts the tire into the fenderwell.
Old 02-13-2009, 08:35 AM   #15
ddongbap
I've seen tires replaced under 5k miles, due to some rubbing. That fender can really mess stuff up.
With that said, minor rubbing shouldn't be a problem. I've had rubbing on my +38s, but it stopped once the fender lining made a hole.
Old 02-13-2009, 09:31 AM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
tire tread varies in width by much more than 1mm
which means if you rotate tires, you might rub
Old 02-13-2009, 09:32 AM   #17
33OH
Drives: '08 Yaris
I know, I was being a smartass.
Old 02-13-2009, 09:52 AM   #18
BLAZINBLUEVITZ
its rubs on the outside fenderwell like you said but its not that big of a deal. EXCEPT when your trying to be cool making a u turn or something else that requires you to turn steering wheel hard.......
Ideal Spacer Width For the Rear? tk-421 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-27-2009 05:59 PM
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 04:24 PM
Post your ideal (dream) girlfriend(s) here! TEHxFALLEN V1.2 Off-topic / Other Cars / Everything else Discussions 14 11-24-2008 05:54 PM
Ideal Offset? 15x7 ET42 Wheels TRD_Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-18-2006 04:12 AM
