Old 02-13-2009, 01:39 PM   #1
chief broom
Drives: 2008 Black LB
Cheap Spring Install
I have been looking for the cheapest place in the St. Louis area to get lowering springs installed, and so far haven't found anything I would call cheap. Does anyone in the area have any suggestions? Thanks
chief broom is offline   Reply With Quote
Old 02-13-2009, 02:14 PM   #2
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
do it yourself!!! all the cool kids are doing it, there is a write-up on here telling you what to do, rent the tool from autozone and you are good to go, cost is free
turboyaris is offline   Reply With Quote
Old 02-13-2009, 02:16 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
what tool do you speak of?
spring compressor?
it's not needed
Old 02-13-2009, 02:28 PM   #4
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I used a spring compressor on the fronts, although like Tamago said, it's not really needed. If you want a bit of extra safety you can use it. They're usually free to rent at Autozone/Shucks/Kragen/Checker ($50 refundable deposit).
On my xB, the fronts literally did not need a compressor. My Yaris front struts were under a bit more pressure, though.
Old 02-13-2009, 09:40 PM   #5
chief broom
I would love to do it myself, but my apartment does not allow automotive work to take place in the parking lots... and I have no mechanical skills
Old 02-13-2009, 10:25 PM   #6
pst4life
Projekt Sreet Tunzers
pst4life's Avatar
Drives: white yaris s with intake and
that sucks buy the spring and go to a shop and see if they can do it for u or just go to a friends house and do it there
pst4life is offline   Reply With Quote
Old 02-14-2009, 12:30 AM   #7
texkid
The one with cheese on it
Drives: '10 Corolla S
I understand your apartment issue. But you don't have a friend that is a gearhead? All guys know at least one person that knows something about cars. I am NOT mechanically inclined, I am just a cheap bastard, thats why I work on my own car. Nonetheless, changes the springs are almost the easiest thing you can do next to changing the motor oil.
The best way to describe, its almost like changing a hard drive, you have to move certain parts out of the way to change one piece and then put everything back together.
texkid is offline   Reply With Quote
Old 02-14-2009, 02:34 AM   #8
ddongbap
Except the pieces are like, 63x larger.
Old 02-14-2009, 05:12 AM   #9
texkid
Lets not split hairs here.
Old 02-14-2009, 10:12 AM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
i never thought i'd see a harddrive and suspension compared to each other. . i've officially reached the end of the internet...
Old 02-14-2009, 05:11 PM   #11
pst4life
pst4life's Avatar
wow really 63x larger then u must be weak if u can pick up a box with springs in it
Old 02-14-2009, 10:50 PM   #12
texkid
LMAO! I like using analogies no matter how weird it may sound.
Suspension install: Spring Compressors? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 09-18-2007 10:59 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
