Old 02-27-2009, 09:30 AM   #1
adeal
Drives: VITZ 2005 1,000CC
where is the ENgine Number?
Guyz i would like to know where is the engine number located. I have a 2005 vitz Japanese. i need to know the engine number for registration purpose. Thank You.
adeal is offline   Reply With Quote
Old 02-27-2009, 09:31 AM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i wanna say in the door jam on the info tags...but im probably wrong.
Old 02-27-2009, 09:48 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
under the hood you'll see a yellow sticker with info about the engine. the code will be on that sticker
http://en.wikipedia.org/wiki/Toyota_SZ_engine#1SZ-FE
Old 02-27-2009, 09:51 AM   #4
mikenacarato
SIPNDEW
Drives: 15 STI
that tag has the ESN on it or is it just the Engine Code?
Old 02-27-2009, 09:53 AM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
it's usually a vacuum diagram and will say the engine code. depends.. either way it's a 1szfe engine
Old 02-27-2009, 09:55 AM   #6
mikenacarato
SIPNDEW
Drives: 15 STI
ah, well i think he may want the engine serial number, not the engine code. but ill let the user tell us. :) some places have to register the ESN for theft recovery, not us though.
Tamago, whats with the 6mm red line anyhow? I would love 6mm wider fenders. haha
Old 02-27-2009, 10:01 AM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
Ahhh my mistake!
and it's a kind-of parody.. the red line.. it won't be my sig for long :)
Old 02-27-2009, 10:03 AM   #8
mikenacarato
SIPNDEW
Drives: 15 STI
haha, cool. well im gonna drive down there and you can make my fenders 6mm wider if you want...to get rid of my rubbage issue. :)
Old 02-27-2009, 10:04 AM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
camber will heal your rubbage issue
-1deg of camber will give you approx 5.3mm of outer sidewall-to-fender clearance on a 205-55-15
Old 02-27-2009, 10:27 AM   #10
adeal
@mike
yes I need the ENGINE SERIAL NUMBER. come on guyz help me out here. its not in the doors n there is no yellow sticker either. its a Japanese model. I believe in you guyz. You guyz can do it. LOL.
Old 02-27-2009, 10:39 AM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
it's between cyl1 and cyl 2, on the block, just below the head, front side of the engine, behind the intake manifold. you'll need a mirror or an orthoscope
Old 02-27-2009, 11:18 AM   #12
adeal
@tamago
i have a steel engine sheet covering that area in front of the engine. and right behind are the intake manifold. i did not see any more. on the engine i can see 1-KR its on the right front upper side of the engine. but that is engine type no good for me.
Old 02-27-2009, 11:20 AM   #13
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
not sure on this... cant you check it in the vin?
Its a Chao!!!
Old 02-27-2009, 11:26 AM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
the actual serial number of the engine is what he needs.. if the engine has been swapped out the vin and SN wouldn't match
OP, sorry, best guess i could give!
Old 02-27-2009, 11:35 AM   #15
adeal
this is a Japanese model vitz imported form japan there is no vin number. thanks guyz for all your help.
Old 02-27-2009, 11:53 AM   #16
it has to have a vin.
Old 02-27-2009, 11:56 AM   #17
mikenacarato
SIPNDEW
Drives: 15 STI
if the vin plates were removed...try moving the passenger seat all the way back, look at the floor, if you see a plastic cover the open it up and the vin is under that as well. with the vin you can call the dealer and they can get you the ESN, but you said its imported so you may have to have someone do it for you..IE whoever imported the car.
Old 02-27-2009, 11:57 AM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
it's also STAMPED to the firewall behind the wiper tray
FS: Used Beatrush Engine Roll Stopper FunctionSpec Items for Sale by private party 7 06-02-2010 01:38 PM
engine swap update Adriaan Canada 5 03-03-2009 06:21 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
