Old 02-28-2009, 07:22 PM   #1
tk-421
tk-421's Avatar
Drives: 5D-07-LB
SLIME Tire Repair Kit
http://www.amazon.com/Slime-Powerspa...m_cr_pr_sims_t
Anybody have any experience with this kit? I'm thinking about ditching my spare tire. TIA
Old 02-28-2009, 08:20 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
if you do not mind your car vibrating to holy hell, it is ok
slime = moving weight in your tire, causing a MAJOR balancing issue
Old 02-28-2009, 08:29 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I see...
What if I were to do an even coat of slime on each tire to prevent flats? Would the even distribution help with the vibration issue?
Old 02-28-2009, 08:38 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
Looks like that kit takes up almost as much room as the donut spare!
Curious... why are you "thinking about ditching" your spare anyway?
Old 02-28-2009, 08:44 PM   #5
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Well, I don't want to have the kit on the car the whole time... Just the bottle itself I guess. But even if I were to have the whole kit in the trunk, I can at least tuck the box to the side... Plus I'm guessing it weighs less than the spare wheel/tire too.
Basically, I want to ditch it because of the weight benefits, and because I don't rub on bump stops as much (I'm lowered with NFs).
Old 02-28-2009, 09:22 PM   #6
06vitzRS
Drives: 06 Yaris HB
If you get a flat tire, no legit tire shop will fix it if it has that type of stuff in it. Most of the chemicals seep into the rubber and make it hard for a plug and patch to stick. So you might get out of a jam by having the Slime in there but if you do get a hole the tire needs to get patched, you'l be looking at a new tire. I will never run any of that stuff in my tires.
4th year apprentice mechanic.
06vitzRS is offline   Reply With Quote
Old 02-28-2009, 10:10 PM   #7
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
if you read the back of the bottle of slime, it states that it is meant to be a temporary fix and the tire should be replaced ASAP. ALSO during winter time, having the can in the car tends to freeze the slime inside and prevents it from coming out well.
Old 03-01-2009, 12:18 PM   #8
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
just keep the spare and make sure the psi is kept up @ 60
Old 03-01-2009, 12:56 PM   #9
MadMax
MadMax's Avatar
I would think Slime would ruin the tire pressure monitors as well...
And the spare doesn't weigh or take up that much room to bother removing it.
Just wouldn't be worth the trouble, if you ask me.
Cheers! M2
Old 03-02-2009, 03:38 PM   #10
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Hi
I have seen the stuff that gets hard inside the tire, so it won´t "travel" in the tire when you drive. GM uses that stuff as a standard instead of spare tire.
When it has been used you need to buy a new can, that´s expensive, and then you need to buy a new tire as the old one is ruined of the stuff.
I would definitely go for the spare tire or replace tires with run on flat technology.
Regards Steven.
Danish Yaris is offline   Reply With Quote
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Power Enterprise Super Charger Kit Round 2 $3100 Power Enterprise Evan Forced Induction Forum 312 03-26-2009 06:48 PM
SLIME - soluciones elegantes para la prevención y la reparación del neumático!!! pensadorcritico Central and South America 0 10-01-2007 12:19 PM
