Old 03-01-2009, 05:08 PM   #1
JetfireK
Drives: 2008 3 Dr Liftback
Maintenance Light Comes on?
I had my Yaris serviced, could this be because the tech forgot to do something on his computer and its time for the 5,000 mile checkup? Although I had it serviced at 4,000 miles , not due again for 10,000 mles...
Will appreciate your thoughts
JetfireK is offline   Reply With Quote
Old 03-01-2009, 06:18 PM   #2
NJBob
NJBob's Avatar
Drives: 2008 Yaris Liftback
Prolly 5k "change your oil" reminder. To reset:
1. Turn the ignition key to the "OFF" position with the trip A reading shown.
2. Turn the ignition key to the "ON" position while holding down the trip meter reset knob.
Hold down the knob for at leat 5 seconds. The indication light flashes and the bars displayed in the odometer disappear gradually. The odometer indicates "000000" and the light goes off.
If the system fails to reaset, the light will continue flashing. "
Old 03-02-2009, 11:28 PM   #3
Kal-El
Kal-El's Avatar
If you had it serviced (oil change) at 4,000 miles, than the light will come on at 9,000 miles. It comes on at 5,000 intervals (it actually appears at 4,500-4,999 upon start-up then disappears but stays on after 5,000).
And remember, this light is specifically an oil change reminder light and doesn't indicate any other needed service. Consult your manual for other service intervals.
Old 03-07-2009, 03:44 PM   #4
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
WRONG, light comes on at 5,000 mile incriments no matter what mileage oil was changed at. 5k 10k 15k,etc.....
Old 03-07-2009, 04:45 PM   #5
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Hmmmm....coulda sworn mine comes on like previously posted, if I reset it at 43,000 sure seemed like it reapeared 4,500-5,000 later
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 03-07-2009, 04:54 PM   #6
supmet
Drives: 2007 4 Door Yaris
Ya.. mine turns on depending on when I changed it last, not on specific preset increments.. it has never come on at an multiple of 100, 1000, or 5000. So whatever mileage you reset it at plus 4500 is when it starts flashing, and then plus 5000 is when it stays on.
Old 03-03-2009, 03:51 AM   #7
phenoyz
phenoyz's Avatar
Drives: yaris
this was what i wanted to know...thanks
phenoyz is offline   Reply With Quote
Old 03-07-2009, 03:16 PM   #8
Fenrizwolf
I used to have more posts
Drives: '10HyundaiTucson'07Impreza
thats in your service manual....
Fenrizwolf is offline   Reply With Quote
How do I reset maintenance light? Snake DIY / Maintenance / Service 10 06-04-2010 12:57 PM
maintenance light blinks gwasabi DIY / Maintenance / Service 16 12-29-2008 12:10 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
