Old 03-02-2009, 10:28 AM   #1
JAMMAN1701
Drives: Toyota Yaris 2007
Yaris Tire Pressure Help
Hello everyone
I am new to this forum and just recently bought my first car.
It is a 2007 Toyota Yaris 1 Ltr
My question is if anyone knows what the standard tired pressure should be for the my car?
I think it is 32psi but I would be grateful if you could help me.
Thanks for reading :)
JAMMAN1701 is offline   Reply With Quote
Old 03-02-2009, 10:37 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
should say in the doorjam what pressure to run... :)
32-34 should work ok
Old 03-02-2009, 12:14 PM   #3
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
The tires have a max pressure number on them. I use that minus 2lbs for (what I feel is) best grip and best fuel mileage, without overstressing the tires.
Old 03-02-2009, 01:03 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
max pressure on a tire is for seating beads....
do NOT run your tires at 48psi lol
Old 03-02-2009, 01:27 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Geez, don't run your tyres anywhere near max pressure!
Old 03-02-2009, 01:34 PM   #6
supmet
Drives: 2007 4 Door Yaris
High Pressure = Best mileage(FE)
Low Pressure = Best Grip
And ya, what kimona and tamago said.
Old 03-02-2009, 03:03 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
should be qualified:
too-high pressure, best mileage, no grip, improper tire wear
too-low pressure: better grip in a straight line (softer sidewall) but worse grip laterally (softer sidewall) improper tire wear
optimal pressure: best compromise of economy and grip.
Old 03-03-2009, 12:04 PM   #8
TLyttle
TLyttle's Avatar
"Optimal pressure: best compromise of economy and grip." I thought that is what I said; it is what I meant to say. I am getting good grip and excellent FE by running my OEM tires ~4lbs over recommended pressure, with no unusual tire wear pattern.
Then the whole thing goes sideways when you see what the hyper-miler guys are running!
Old 03-03-2009, 12:35 PM   #9
kimona
kimona's Avatar
This is what you said. I don't know about your tyres, but mine indicate a maximum tyre pressure of 50PSI. So, 50-2 = 48PSI... which would be somewhat overinflated. If I inflated my tyres to 48PSI, I'd be bouncing all over the road like a basketball!
Old 03-03-2009, 02:04 PM   #10
JAMMAN1701
and just a follow up question. should I have each tire at the same psi eg 32 psi on all 4 tires?
And I cant seem to find it written anywhere around the door :(
Old 03-03-2009, 02:48 PM   #11
kimona
kimona's Avatar
Should have a label affixed to the driver's door jamb that indicates tyre pressures and loads. Label on my Vitz clearly indicates 32PSI front/rear.
psi, tire presure, yaris
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
Im in Yaris heaven..... (Special Edition Yaris) YAR1S Photo-Video-Media Gallery 77 06-16-2010 10:55 PM
Tire Pressure Monitor Sensors....? 09TRD Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-19-2008 09:25 PM
