Old 03-08-2009, 08:01 PM   #1
anubisx99
here again..
anubisx99's Avatar
Drives: 2008 toyota yaris LB
GPS help...
can anyone tell me where can I find the speedometer wire for the GPS unit?..
I just upgraded my radio for an AVIC F900B and I need to know which is the speed signal cable for more accuracy ....help any one?
Don't be threating me with a good time!!!
anubisx99 is offline   Reply With Quote
Old 03-08-2009, 11:18 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
gps will tell you ur speed which is more accurate the the car speedometer.. i dont think you need to hook it up mine shows my speed while im using it. unless were not on the same page then forget this reply.
Old 03-09-2009, 11:14 AM   #3
marcus
toyota
marcus's Avatar
over a constant speed the GPS will be more accurate than the speedo, however the refresh rate is not fast enough to give you instantaneous speed like the speedo. also depending on the environment (tall buildings ,tunnels etc) will prevent the GPS from giving you a good on the fly readout. now this is minized with AGPS (assisted GPS) , for now mainly in cell phones (uses the the cells sites to update the position when the GPS signal is low or non existent.
ur right about that then again i just got my garmin 255..pretty kewl gadget..also tells to to drive on proper speed to save gas with the ecoroute features.. come in handy for hypermillers. well sorta not as good as the scangauge2.
Old 03-09-2009, 09:02 PM   #4
anubisx99
here again..
anubisx99's Avatar
thanks guys... yes, my GPS tells me the speed however a few of my friends tell me that if I hook up the speed sensor wire (which I did -thanks Arquitect-)it would make the GPS more accurate since it calculates both speed reads (cluster+satellite) well I'm no tech so that's what they told me though, also after hooking it it's a little better, still off though...my AVIC-D3 that I had before this one was 100% accurate (tested many, many times) in the city or not...
Need GPS Help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 16 01-29-2009 11:10 AM
Best spot for GPS onizuka Canada 29 11-19-2008 01:23 AM
compusa $160 after rebates GPS Blenjar In Car Entertainment + Electronics (audio / video / alarm) 8 06-04-2007 01:19 PM
Do you have a portable GPS Driver Off-topic / Other Cars / Everything else Discussions 8 12-13-2006 01:37 AM
