Old 03-09-2009, 10:54 AM   #1
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
Project Slowtop Stage 2 - Twin engine
Hey guys,
Its been a while since i've updated anyone on my Project Slowtop.
For thoes who don't know I have a 2005 Toyota Echo 2Door Hatchback. It was a former Echo Cup race car.
Last Summer Turbine Tech has swapped in a 4age blacktop with 6speed transmission plus a turbo setup.
After driving it for a few months i needed for it to be faster ;) We had may discussions on what to do. First i wanted to get a supra 2jz motor and make the echo RWD. But that ended up being too much trouble. There was complications in fitting the steering rack... the fire wall had to be pushed back... So we scrapped that idea.
Then i thought of using the awd system from an Echo in japan but it was next to impossible to source the parts and shipping and importing it would have been a nightmare. And it would have most likely cost more then the 2jz setup... so back to the drawing board.
I was stuck on having a RWD car. After going around the track in an s2000 this past summer i knew it was a must! Or even better having an AWD setup (Turbine Tech pulsar GTiR is just so amazingly fast it blew my mind)
I throw out the idea of moving the blacktop motor to the rear and making a mid engine echo! the crazy Aygo is unbelievable with its mid engine setup. so after cruching some numbers Jess got back to me and said its going to be more cost effective to do a twin engine setup.
2 X 4age Blacktop motor
2 X Turbos
2 X 6 speed transmissions w/ LSDs
______________________________
2 X the fun!
So here is the first photo of the Twin Engine Blacktop Echo. For everyone's enjoyment. I'll have some photos come april IF its ready for the car show.
Special thanks to Turbine Tech!
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 03-09-2009, 10:58 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
twin engine! doing it like the europe has been for decades, very cool
i'm interested in more than pictures. where are you going to put your fuel tank?
Old 03-09-2009, 11:12 AM   #3
do it!
Old 03-09-2009, 11:26 AM   #4
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
moar pics!
Russelt3hPirate is offline   Reply With Quote
Old 03-09-2009, 02:13 PM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
If you get that thing working properly you are going the become my new heroe...
That is some MAJOR project you got there!
One question... concidering you are going the turbo route...
Didn't you concider the 4AGZE instead? cheaper and can make 300whp on it's stock form with no troubles.
BTW, my uncle has a Pulsar GTi-r... amazing little car!
Old 03-09-2009, 03:35 PM   #6
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
ITB's FTW
Old 03-09-2009, 04:02 PM   #7
White Yaris
Broke Tuner
White Yaris's Avatar
Drives: White Yaris
mad science project! do it!
EVERYTHING YOU KNOW IS WRONG
White Yaris is offline   Reply With Quote
Old 03-09-2009, 04:37 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
http://www.toysport.com/technical%20...tech_notes.htm
this is a good read
Old 03-09-2009, 05:08 PM   #9
CASTREX
CASTREX's Avatar
Nice info!
What I meant about the AGZE is that is already boost friendly...
Just throw the SC away and snap a T28 turbo and you can be pushing 250-300 whp all day long.
Super strong OE rods, forged low comp pistons, oil squirtes...
While a black top will need rods and pistons to ba able to handle real boost.
For N/A... the 20V with it's ITB's would rule...
Old 03-09-2009, 05:32 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
Nice info!
i ran a corolla FX16 with 20V blacktop swap.. walked him
boost > NA
toysport still recommends changing pistons for applications over 10psi..
down here the 4EFTE is the engine of choice, much more stout than the 4AG, it doesn't spit head gaskets as much.
Old 03-10-2009, 09:20 PM   #11
turboecho2005
Well people will argue which is better... the 4agze or the 4age 20v. Sure for boost the 4agze out of the box is better but you can eventually make more power from the 20v motor with some nice rods and pistons. Plus the 20v motor comes with ITBs, 6 speed transmission with LSD, a better flowing head. Just need some good head studs and a metal HG.
Also the car now has independent suspension in the rear :) so it should handle quite a bit better on the track.
Old 03-11-2009, 12:25 AM   #12
CASTREX
CASTREX's Avatar
^^^ yeah you are right about that...
It was just my budget oriented mind speaking....
I guess, for some one who changes his engine once a year, adding a few extra pistons and rods to the modifications list is not much of a problem!!
Old 03-11-2009, 12:28 AM   #13
ae92trueno7
ae92trueno7's Avatar
Drives: 2007 Yaris Supercharged
nice!!! hopefully that goes well!!! 4age!!!! is better i think.... u can get the mr2 supercharger on it!!!
ae92trueno7 is offline   Reply With Quote
Old 03-11-2009, 02:32 AM   #14
Can you start another thread showing how you did that?
Old 03-11-2009, 07:12 AM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
it'll be a complete MR2 subframe most likely
but as he said in the first post, the engine really isn't mounted yet, much work to be done!
Old 03-11-2009, 07:13 AM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
lol, that eaton piece is garbage.
he'll be making much more power than the stock SC would be able to produce
Old 03-11-2009, 08:29 AM   #17
turboecho2005
Actually the picture has the motor mounted with all the suspension is mounted. It's currently a rolling chasis! All the fabrication of the motor mounts and suspension is complete.
Old 03-11-2009, 01:30 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
more pix please!
New audio + Today's DIY project TEHxFALLEN V1.2 Photo-Video-Media Gallery 23 03-03-2009 11:37 AM
New Project AE86...! CASTREX Photo-Video-Media Gallery 29 02-01-2009 03:09 AM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
My Stage 2,3,4 tuning list Hyde General Yaris / Vitz Discussion 17 08-06-2006 05:32 AM
