Old 03-12-2009, 08:55 PM   #1
xxae07xx
hook em
xxae07xx's Avatar
Drives: black 08 lb
adjustable camber bolts....
anyone installed them?? bot some but came with no instructions...
xxae07xx is offline   Reply With Quote
Old 03-13-2009, 01:03 AM   #2
YarisSedan
Drives: 08 Yaris Sedan
You remove the old bolt and install the new one? Wouldnt you be having a alignment shop be doing this since they would be the ones adjusting the camber.
Old 03-14-2009, 03:15 PM   #3
ri_espinosa
ri_espinosa's Avatar
Drives: Toyota Tercel
Send a message via MSN to ri_espinosa Send a message via Yahoo to ri_espinosa
check this...
http://www.microimageonline.com/csAr...000/000036.htm
ri_espinosa is offline   Reply With Quote
Old 03-14-2009, 04:16 PM   #4
Morgan
Morgan's Avatar
Drives: 07 MM LB
remove wheel, undo stock bolts, replace with crash bolts, push the top of the assembly in and pull the bottom of the strut assembly out - voila!
put the wheels back on and then promptly take it to an alignment shop so they can adjust toe in closer to neutral...
Old 03-14-2009, 04:33 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
obvious answer is obvious!
Tighten bolts to factory specs? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 10-19-2010 05:18 PM
Gauging Interest: Whiteline Front/Back Adjustable Sway Bars RaptorRacing Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 12-15-2009 04:23 AM
Adjustable Camber Bolts cali yaris Micro Image 30 12-11-2009 09:38 AM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
Who makes camber bolts? largeorangefont Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 07-08-2007 12:22 AM
