Old 03-13-2009, 12:04 AM   #1
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Mid-pipe-to-axleback muffler Gasket question???
Just installed a megan header and nitto mid-pipe hooked up to my hks hi-power exhaust and there is a desent exhaust leak where the end of the mid-pipe meets the muffler flange(re-used stock donut gasket) . I read a couple post saing not to use to stock gasket(donut) with this set-up cause its too small , so what gasket is everyone with a similar set-up running
thnx
Old 03-13-2009, 01:22 AM   #2
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
well, there are various gasket materials on the market you can buy in sheets so you can make your own gasket...also, there are metals you can use in thin strips as gasket material, pliable alloys such as copper.
personally, i just chopped off my exhaust after the cataletic converter and welded on a long glasspack the lenth of my sedan...i dont like gaskets...they leak.
edit: ensure the material you purchase is for high temp aplications and not the cork crap for valve covers.
Old 03-13-2009, 01:30 AM   #3
YarisSedan
Drives: 08 Yaris Sedan
Theres a product called muffler weld that you can use in substitute for a gasket
Old 03-13-2009, 01:31 AM   #4
blacksandiegovitz
Drives: 08 Vitz
Well I've owned 5 turbo cars so I've been around the block with custom/1-off gaskets all day long and I know what I could due . I just wanted to know what people with this same/similar set-up are running gasket wise .
Old 03-13-2009, 01:34 AM   #5
blacksandiegovitz
Drives: 08 Vitz
Yeah I got some copper Atv thats worked in a pinch with upgraded turbo set-up i've ran in the past . So i might just run some for now , as i'm bombing up to aneheim for hin tommorow and dont want to listen to the exhaust leak on the drive up and I have no time to waste with the wrong gaskets/trips to kragens lol .
mid pipe swap shinlee Performance Modifications 0 02-09-2009 10:44 PM
Nitto Mid Pipe ztrack157 Willing to Buy by private party 2 01-18-2009 04:00 PM
looking for a STOCK mid pipe... shinlee Items for Sale by private party 6 01-16-2009 08:15 PM
Exhaust pipe gasket umm_bacon DIY / Maintenance / Service 1 09-23-2007 07:30 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
