Old 03-15-2009, 02:05 AM   #1
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
aveo dome light trouble
my girlfriend has an 06 aveo. her dome light works about 10% of the time, whenever it feels like it. wanted to be her hero and fix it, so i checked fuse and bulb. both seemed fine. any other likely answers?
Club SHIFT
Old 03-15-2009, 02:09 AM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
If it only works once in a while, look at the wires for fraying and look at the switch itself. If there is also trouble when you open and close doors, look at the mushroom switcheds at the doors.
Old 03-15-2009, 03:56 AM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Try changing the bulb. It may be a broken connection between the glass bulb and the metal that connects to the socket.
Old 03-15-2009, 10:51 AM   #4
I'm afraid the answer lies much deeper than that, and it's gonna be costly and hard to fix:
it's a chevy/daewoo...
But seriously yes, sounds like a bad contact in the wiring somewhere, good luck finding where!
Old 03-15-2009, 12:44 PM   #5
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Thomas beat me to it, lol...
Just try the bulb, I had the same problem with one of my parking lights on the Yaris, after I reinstalled the old bulbs once my LEDs blew.
Old 03-16-2009, 08:25 AM   #6
SailDesign
Drives: .
I would buy her a whole new dome light, preferably wrapped up in a new car.... sometihng like a Yaris...
Old 03-16-2009, 02:50 PM   #7
jeremyshay
jeremyshay's Avatar
Drives: 07 Meteorite Metalic Liftback
Send a message via AIM to jeremyshay
this man speaks the truth! although truth be told. past yotas have had this problem, but not new! haha
You don't get it, do you? This isn't "good cop, bad cop." This is fag and New Yorker. You're in a lot of trouble.
~Kiss Kiss, Bang Bang
jeremyshay is offline   Reply With Quote
Old 03-16-2009, 03:11 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
Old 03-16-2009, 07:52 PM   #9
SailDesign
Drives: .
Dies
At
Every
Wide
Open
Opportunity
Old 03-18-2009, 12:39 AM   #10
TickleTimeTim
Free Mustache Rides
ha. yeah, not a fan of aveo. wish she would've gotten an 02 jetta like originally planned. thanks for the advice. will try bulb, then door mushrooms (ha), and if i can get to it, wiring behind the dome.
Club SHIFT
Old 03-18-2009, 01:08 AM   #11
YarisSedan
Drives: 08 Yaris Sedan
More than likely the contact inside the dome light housing is bent. You could try bending the tabs a bit and see if it works again. If not just place the whole dome assembly. Maybe 30 bucks for a used one. If you know how to use a multi-meter. Check the voltage at the terminals the dome light connects to and having someone open and close the door. See if the voltage is always constant when door is open like it should be.
12 LED Dome Light Festoon bigsky2 Cosmetic Modifications (Exterior/Interior) 26 04-18-2010 10:38 AM
Trouble putting 3rd brake light after rear speaker install..... YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 5 12-05-2008 03:10 AM
Dome light dimm slvryaris DIY / Maintenance / Service 3 12-02-2008 08:06 AM
Festoon (dome light) led bulb fit?? ||)) (o) ||\|| Cosmetic Modifications (Exterior/Interior) 5 03-22-2007 02:22 PM
