Old 03-15-2009, 02:33 AM   #1
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
Tech Help!!! for company Scion xb
I have a xb that belongs to my company. The dumb driver blew the engine. The #4 rod had knocked a hole in the oil pan and both sides of the block.
Anyway,
Put in a used engine and the starter wont engage correctly.
There is a dent in the starter where a chunk of the block hit it.
There also was metal shavings in the bellhousing and starter.
I cleaned out the starter and the bellhousing (took the starter apart)
I thought everything was good but.... I NEED HELP.
Could someone with a automatic and mechanical know-how remove the plastic inspection cover that covers the flexplate and tell me or take a photo of the flexplate teeth. I need to know if you can see the welds on the flexplate to the teeth or if there is a 1/4 inch lip on the teeth to the flexplate. If so I put the darn flexplate on backwards . If not I have a bad starter.
I also posted on the xb board but the yaris has the same engine, And I have been here b4.
07 Yaris LB,Red.Gone to Yaris Heaven,I miss her.
06 TC Limited -lease almost up. Woohoo
85 Supra-- White
82 Supra -- Red, Black 1JZ
98 Dodge ram quad cab green - beater truck
tiksman is offline   Reply With Quote
Old 03-15-2009, 09:18 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
sounds like you need to take it to a mechanic.
none of us can do any of that via the internet lol.
Old 03-15-2009, 10:55 AM   #3
tiksman
tiksman's Avatar
Duh, I am the mechnic. I just dont remember the way it was on the car.
85 Supra-- White
Old 03-15-2009, 10:58 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
did you try downloading the toyota service manual?
Old 03-15-2009, 02:02 PM   #5
tiksman
tiksman's Avatar
Yes I have it but it is hard to tell by cad drawn pictures. I have looked it over many times . I think the starter is Fubar.
85 Supra-- White
Old 03-15-2009, 05:51 PM   #6
silver_echo
ekodrvr
silver_echo's Avatar
i would say that with the DENT in the side of the starter, that it might be dead... but on the starter ring gear, can you see the witness marks from the starter? if so, do they line up with the starter when you turn the flex plate? if not, your vehicle may very well have the flex plate on backwards...
silver_echo is offline   Reply With Quote
Old 03-16-2009, 01:04 AM   #7
YarisSedan
Drives: 08 Yaris Sedan
Have you tried posting on the scion forums?
Old 03-20-2009, 09:38 PM   #8
tiksman
tiksman's Avatar
YES, But as I thought I got more responses here
The flexplate was on backwards.
There is a ring hump around the plate and that ring faces inside.
So raised portion to the inside(engine) and dip to the trans (converter) side.
Swaped it out today 3 hrs to pull engine, turn plate around and get the engine back in. I have to hook everything back up but I should be done tommorow.
85 Supra-- White
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
Meras Dudas ??? FJ YHBCR Central and South America 8 09-20-2007 11:01 AM
Scion xD Rudeshady Central and South America 1 06-25-2007 01:11 PM
NEW: 2008 Scion xB (Not bB anymore) and xD (Bye Bye xA) Treyz Photo-Video-Media Gallery 18 02-22-2007 02:59 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
