Old 03-18-2009, 12:34 PM   #1
mrbond
mrbond's Avatar
Anyone put in a performance radiator?
I was thinking of putting in a Koyo radiator, but seeing as how seemingly no one had installed a different radiator than stock, I'm questioning if I should do it. Plus I'm not sure if the fitment would be correct, considering there's the a/c cooler in front...
Anyone with any input/feedback?
- A Toyota Yaris
- A whut Yaris?
Old 03-18-2009, 12:56 PM   #2
My input is that you should be very clear why you want to do this.
I understand the possible need on a boosted and/or race-prepared car, but for the street I'm not sure there's any point. Unless you want points for car shows?
Old 03-18-2009, 01:01 PM   #3
agreed, the stock radiator has PLENTY of cooling capacity, even on the really hot and humid tropical summer days here I never see abnormally high temps...
Old 03-18-2009, 01:03 PM   #4
mrbond
mrbond's Avatar
Yeah, I was planning on it being a show piece...and added cooling is almost always a benefit. See, the radiator is only like $145, which isn't bad at all. If it were above maybe $200 I wouldn't bother.
Garm, you probably know way more about this than I do: are the stock radiators adequate enough for street driving? Like, say, when the outside temp is around 95 and the a/c's on full blast? I had an issue with my Contour overheating and it caused uncountable problems; I don't want to repeat it with my Yaris.
- A Toyota Yaris
- A whut Yaris?
Old 03-18-2009, 01:04 PM   #5
mrbond
mrbond's Avatar
Ah, Thomas, you answered my question just seconds before I asked it. It's that Thai cuisine that gives you telepathic powers :P I love Thai curries, btw.
- A Toyota Yaris
- A whut Yaris?
Old 03-18-2009, 01:07 PM   #6
nah it's just a result of the nuclear testing...
Old 03-18-2009, 01:11 PM   #7
mrbond
mrbond's Avatar
^ haha reminds me of homer simpson: "it's pronounced nucular, lisa"
while we're on this topic, what is the "safe" operating temp range? by safe, i mean the threshold before there start to be issues.
- A Toyota Yaris
- A whut Yaris?
Old 03-18-2009, 01:39 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
the thermostat opens and allows coolant to flow from the radiator into the water pump..
that's the threshold.
even in boost, on a hot day, i never saw coolant exit temps (from the stock radiator) higher than 160F
spend your $145 on something shinier IMO
Old 03-18-2009, 03:22 PM   #9
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
According to my ScanGauge, my normal operating temperature is 184F. On hot days and stop and go traffic, I've seen it climb to 200F.
In fact, at the last autocross, it was hot and as we inched forward to the starting line, the temp went slightly over 200F. I kinda started getting worried. Obviously, there was no boosting going on in the paddock.
Old 03-18-2009, 03:29 PM   #10
mrbond
mrbond's Avatar
LtNoogie, you had your Blitz already installed for that autocross, correct? And it wasn't even on? You said it was hot - do you remember the on-track temp?
You know, I'm considering alternatives to the radiator. Like, an upgraded fan from Mishimoto or some other reputable company, an engine oil cooler, and/or those little cooling fin sheets from ARC that attach themselves to the engine block and the oil pan. If the radiator is sufficient enough for hot temperatures, even with a boosted car, then problems would lie in other methods of cooling.
- A Toyota Yaris
- A whut Yaris?
Old 03-18-2009, 03:34 PM   #11
LtNoogie
LtNoogie's Avatar
I think it was in the mid-80's with no breeze. As long as the car is moving, the water temp will drop. To be honest, once they waved the green flag, I stopped looking at the ScanGauge.
Correct, unless I am at 25% throttle, the compressor does not engage. I am wondering what water temps other people are seeing at idle on a hot day?
Old 03-18-2009, 03:42 PM   #12
mrbond, use that money for a gauge! Nice and showy and you'll know what your temp is
Old 03-18-2009, 04:13 PM   #13
mrbond
mrbond's Avatar
haha, actually i was planning on buying one before the end of the month! my paycheck comes in the tuesday after next :D
off the temp topic, how much are the carbotech (sp?) brake pads? i don't see them on your site :(
- A Toyota Yaris
- A whut Yaris?
Old 03-18-2009, 08:57 PM   #14
I need to add them -- so many parts, so little time I'll get to that tonight.
Old 03-18-2009, 09:39 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
yes, but if you want to know a radiator's efficiency, you need to measure water temp at the outlet to the radiator.
Old 03-18-2009, 09:40 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
why not buy a lower-temp thermostat?
Old 03-18-2009, 09:41 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
you should buy my defi setup ;)
Old 03-18-2009, 09:43 PM   #18
mrbond
mrbond's Avatar
Wouldn't a lower-temp thermostat just open up at a colder temperature? I considered it but I didn't see how it could help cool the engine in a hotter climate after having driven for a while... Maybe I'm missing something? If I am, let me know because I want to learn as much about the whole cooling side of the Yaris as I can.
- A Toyota Yaris
- A whut Yaris?
The Yaris Performance Primer eTiMaGo Performance Modifications 30 01-24-2024 04:26 AM
New shift knobs available from TWM Performance! TWM Performance TWM Performance 3 06-25-2009 04:24 PM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 12:32 AM
Yaris Performance Specs neohalo Performance Modifications 22 06-24-2007 08:46 PM
