Old 03-22-2009, 09:29 PM   #1
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
Spoiler installation gone wrong
Hey guys,
I got a RS Spoiler and wanted to install it on my yaris....
So I painted it (not the best paint job) and tried to install it
It had two screws that needed to be drilled into the back of the yaris and put in. So I measured the screw width and drilled a 7 mm hole at the back. But the screw didnt go in....
So I took a 8mm drill bit and expanded the hole....
Now the screw is a bit loose
Can you give me a way to fix this stupidness of mine?
Also, I thought it will be fine, so I covered the top of the screw with a cap so that the screw doesnt fall out... now I cant access the screw
Old 03-22-2009, 09:31 PM   #2
3m tape
Old 03-22-2009, 09:37 PM   #3
jinxor
jinxor's Avatar
So you reckon I 3m tape the whole thing onto the roof of the car??
Old 03-22-2009, 09:44 PM   #4
ruimond
Drives: Yaris YR
I was gonna get an RS spoiler, but i'll prob be getting a panel and paint shop to do the work. Where did you end up getting yours from? Sorry to hear about the drillling problem, that kinda sucks.
Old 03-22-2009, 10:16 PM   #5
spookz
JDM yO!
Drives: '09 3dr. 5-spd
Try some automotive double sided tape. You can pick up a roll at your local Bunnings for ~$6-7. Are the caps that you placed on, not removable?
Old 03-22-2009, 10:23 PM   #6
Can't you just use a larger screw?
I ended up drilling holes from underneath and using bolts, washers and nuts -- my spoiler isn't EVER coming off.
Old 03-22-2009, 10:27 PM   #7
jinxor
jinxor's Avatar
from underneath... hmmm... that sounds like a plan as well... If I somehow strip the the back panel from the hatch, I should be able to see the bolts sticking in??
Old 03-24-2009, 12:13 AM   #8
TitaniumBarbell
TitaniumBarbell's Avatar
Drives: Yaris 3Dr LiftBLACK
Have you pics of this installation? Sounds so interesting!
TitaniumBarbell is offline   Reply With Quote
DIY Sedan Spoiler Install Kaotic Lazagna DIY / Maintenance / Service 36 01-19-2020 11:35 PM
Liftback Spoiler Installation Toddhata Cosmetic Modifications (Exterior/Interior) 25 08-09-2009 01:26 AM
RS SPOILER ... SAD aznbabiegrlx0x0 Cosmetic Modifications (Exterior/Interior) 42 09-28-2007 09:49 PM
Rally style spoiler in white for sale!! cheukli Items for Sale by private party 11 07-18-2007 09:02 AM
