Old 03-26-2009, 02:01 AM   #1
silver_echo
ekodrvr
silver_echo's Avatar
greddy e-manage?
there is a guy on one of the other forums that i am on that is selling the kit, and lists it as able to work on the 1nz-fe... anyone tried it? does it work? how well?
i like this smiley...
silver_echo is offline   Reply With Quote
Old 03-26-2009, 01:47 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
The emanage blue has been used with some level of success on the First gen xB / xA and the Echo.
It does not work properly on the Yaris. The ZPI turbo kit used the blue but they also throw the car into a CEL coma to be able to use it...
Old 03-26-2009, 07:46 PM   #3
1nz
Drives: Vios
the emanage ultimate works, even the pretune setting gave better respnse, especially for my auto trans
http://www.yarisworld.com/forums/showthread.php?t=15014
as for emanage blue theres a guy using custom turbo using it:
http://www.gt-auto.net/index.php?opt...d=27&Itemid=55
Please visit us @:
greddyvios.blogspot.com
1nz is offline   Reply With Quote
Old 03-29-2009, 05:17 AM   #4
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
i'm currently using e-manage blue i have no problems with it so far.
changchewsoon is offline   Reply With Quote
Old 03-30-2009, 12:17 PM   #5
CASTREX
CASTREX's Avatar
Haven't you had any problems with the OE ECU re-learnig around the Emanage tune?
Do you have any data log of your AFR's at partial throttle and WOT?
The problem that many people have seen with the emanage and other piggy backs is that cars ECu will quickly find a way to go around it and turn everything back to the orginal tune...
Old 03-30-2009, 04:59 PM   #6
changchewsoon
Drives: Vios Turbo
I do have a dyno chart that shows WOT, hope it helps.
http://www.yarisworld.com/forums/ima...Dyno-Chart.JPG
I do have a Innovate LC-1 wideband, it shows the AFR is between 14-15 during highway cruising at partial throttle.
Yes, actually I do hear from some people claiming that the OEM ECU will adapt itself around the E-Manage. Did it happened to USDM ECU? I'm not too sure about JDM ECU though. We have lots of 1NZ-FE here running different types of piggyback, from E-Manage Blue to E-Manage Ultimate, Dastek Unichip and even SMT.
I'm quite curious myself actually and hence this is one of the reason why I invested in a wideband kit to monitor my AFR.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
Old 03-30-2009, 07:46 PM   #7
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I'm thinking about buying an emanage ultimate just to see if I can do some NA tuning before boosting
Old 03-30-2009, 08:18 PM   #8
CASTREX
CASTREX's Avatar
Well... your AFR's seem to be in good order! just above 12:1 to the red line.
This seems to be another clear example of the difference between the US ECU and other countries...
Are you able to modify the ignition timing with the emanage?
Old 03-31-2009, 02:16 AM   #9
changchewsoon
Drives: Vios Turbo
Thanks, I hope the AFR would stay stable just like that too.
Yes with the E-Manage we're able to control the ignition timing with the additional timing harness. However, by adding a V-Manage we can even fine tune it.
Its sad to know that the USDM ECU and JDM ECU is different, if not we could have shared a lot of common tuning parts together :(
Greddy TiC exhaust For the Yaris Invision Yaris Sponsors Classifieds Area 17 09-07-2007 04:59 PM
Elusive Greddy Ti-C? RShatchback Performance Modifications 36 06-05-2007 04:11 PM
GReddy prototype = Free Exhaust! Chris_Lum California 30 02-27-2007 10:13 PM
Greddy xB Supercharger Papamoon Performance Modifications 2 02-09-2007 03:08 PM
Greddy Intellegent Informer the_saint In Car Entertainment + Electronics (audio / video / alarm) 0 11-12-2006 04:26 PM
